Briggs And Stratton Started Clutch Question
3 replies to this topic
#1 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted March 07, 2012 - 07:42 PM
im am starting to put my 3hp project together and when i put the top of the starter clutch on (the part that catches on the pull start). it doesnt wanta go on and if i do get it on it will not spin freely. IDK whats going on. this clutch came from this engine and everything. I need help
#2 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted March 07, 2012 - 07:44 PM
Have you looked for parts diagrams on the B and S site. I'm not familiar with them myself.
#3 jdslednut OFFLINE
jdslednut
  • 680 Thanks
  • 851 posts
Posted March 07, 2012 - 08:28 PM
If you used a hammer at all to get the flywheel off the crankshaft is probably boogered. Take a flat file and try to true it up and see if that helps. Don't forget to slap a little grease on the shaft once it does turn freely to prevent the squeel and rope upchuck.
#4 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 07, 2012 - 08:42 PM
Ditto, carefully making shure it is filed round.
And make shure the spring is wound up the right way or the tab at the end of the spring did not snap off.
While off the engine's cooling showd pull on the starter handle to check the recoil making shure it recoils all the way and strongly too, if the recoil just spins freely after it is mounted on the crank and does not catch the 6 balls in the starter clutch is stuck, spin off the clutch and remove the cover carfully with out dropping the balls and clean out the clutch and balls untill there are no grease or dirt, spin on the clutch, tighten and a little grease at the end of the square recoil bar.
Edited by trowel, March 07, 2012 - 08:42 PM.
