Paint Removal?
2 replies to this topic
#1 KennyP ONLINE
  • 40,036 Thanks
  • 46,727 posts
Posted March 07, 2012 - 07:12 PM
I have an Onan (aluminum block) that the paint is peeling. What is the best way to prep this for new paint?
#2 chris m ONLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted March 07, 2012 - 07:34 PM
Kenny I use spray can gasket remover, it works great! we used this allot at work, almost like oven cleaner. you spray it on and let it sit for awhile and the paint bubbles up, Then you can rinse it off when done. sometimes you have to do 2-3 times for thick paint. If you can't rinse it then allot of rags a scrapper and water in a spray bottle works too.and it is safe on aluminum.
  • KennyP and JDBrian have said thanks
#3 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted March 07, 2012 - 08:30 PM
Be sure to use a degreaser when rinsing, as the gasket remover will leave a residue, that paint will not adhere to. I like using Dawn dishwashing liquid to clean my parts, before applying paint.
  • lyall and KennyP have said thanks
