Kohler Single Balance Gears
17 replies to this topic
#16 Billygoat OFFLINE
Billygoat
  • 76 Thanks
  • 206 posts
Posted March 08, 2012 - 08:26 PM
To the best of my knowledge (which isn't much) Case also dropped the balance gears when they started using platform mounts on the engine mounting plates. My 444 shakes a bit when idling, but smooths out when sped up. Considering the way the hydraulic system works on these things, there's not much time spent idling.
#17 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted March 09, 2012 - 05:22 AM
I think the balance gears were probably removed by Kohler, some of the Cub Csdets with the K motors didn't have them either.
#18 JDBrian OFFLINE
  • 9,593 Thanks
Posted March 10, 2012 - 10:54 AM
Idling at 2200 isn't really an issue with any hydro powered tractor either. I just wonder if the jetting is different in the carb. It's a bit confusing when you look at the Kohler manual and it tells you to set the idle screw with the rpms below 2000 and JD tells you to set the idle at 2200. One issue is that when you shut down at 2200 the engine is still pulling in fuel for quite a while before it stops and that may contribute to the backfiring problem after shut off that some people have experienced. I'm just glad I don't have to worry about the gears blowing out in my 314.
