1054 Husky Restore
119 replies to this topic
#76 Newpaws493 OFFLINE
Newpaws493
  • 1390 Thanks
  • 1818 posts
Posted April 21, 2012 - 07:48 AM
if the carb. igot off of ebay was refurbish they should have cleaned it, went through it yesterday very dirty better now but still lacking but i'll keep working with it . Posted Image inChrist goodnews
Goodmorning to you 'Goodnews', maybe the seller wanted to say "re found-ish to sell-ish". Do you have any other pics of progress on the deck?
  • goodnews said thank you
#77 goodnews OFFLINE
goodnews
  • 126 Thanks
  • 423 posts
Posted April 21, 2012 - 12:27 PM
Just go nice and slow when your trying to remove the pulleys from the spindle shaft as they are often rusted on and require a puller to get them off. Once you get the pulley and shaft out you can get at the bearings.
I would recommend if you are going to go through the deck to replace the idler pulleys, and belt as well.
thanks doc after i got the first one off which was very hard i saw it had 2 set screws in it so on the next 2 i loosened the set screws and they came off much easier with puller of course. bearings on one was no good but the other 2 felt really good, replace 2 or six? the gear box has about i/8 slop in am i allright with that? :thumbs:
#78 goodnews OFFLINE
goodnews
  • 126 Thanks
  • 423 posts
Posted April 21, 2012 - 12:33 PM
got it stripped getting ready to clean andpaint i'll take a pic today and post them .
#79 goodnews OFFLINE
goodnews
  • 126 Thanks
  • 423 posts
Posted April 21, 2012 - 12:40 PM
offered a man $ 125.00 for his g14 1974 main drive out of it if he takes me up on it i'm wondering what else i'm going to find when i get into it .talk to me fella's while its not late. thanks in Christ :thumbs:
Edited by goodnews, April 21, 2012 - 12:40 PM.
#80 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted April 21, 2012 - 01:04 PM
While you got everything apart I would replace all bearings.
I would pull the gear box apart and clean and inspect the seals, bearings ect and replace what ever is worn.
If you do it right the first time you will save yourself headaches later on... A year or two down the road those 2 bearings will have to be replaced.
And remember, its alot easier to replace things now instead of trying to do it later and get your new paint job all scratched up :thumbs:
#81 goodnews OFFLINE
goodnews
  • 126 Thanks
  • 423 posts
Posted April 21, 2012 - 03:47 PM
IMG_0361 - Copy.JPG IMG_0362 - Copy.JPG IMG_0373 - Copy.JPG IMG_0368 - Copy.JPG IMG_0372 - Copy.JPG IMG_0370 - Copy.JPG IMG_0365 - Copy.JPG IMG_0363 - Copy.JPG IMG_0367 - Copy.JPG
  • JDBrian said thank you
#82 goodnews OFFLINE
goodnews
  • 126 Thanks
  • 423 posts
Posted April 21, 2012 - 03:54 PM
wow that sandblasterwill wear you out but i'm through for the rest of the day nothing now but rest and ribeye yum ,yum .God is good rejoice and give him praise!!!!! :thumbs:
  • Newpaws493 said thank you
#83 goodnews OFFLINE
goodnews
  • 126 Thanks
  • 423 posts
Posted April 23, 2012 - 12:56 PM
got six new bearings instaiied them this moring , deck is primed waiting for sunshine and wamer temp. to paint . rom 10:8 - 13 :thumbs:
#84 Newpaws493 OFFLINE
Newpaws493
  • 1390 Thanks
  • 1818 posts
Posted April 23, 2012 - 03:35 PM
'Goodnews', I'm trailing behind you slowly and started my teardown today, my ears are perked and taking in the details to try and get it right. I just posted some pics...Thanks again
#85 goodnews OFFLINE
goodnews
  • 126 Thanks
  • 423 posts
Posted April 24, 2012 - 05:31 PM
hope to paint wed. weather permiting in Christ
#86 goodnews OFFLINE
goodnews
  • 126 Thanks
  • 423 posts
Posted May 01, 2012 - 05:35 PM
#87 goodnews OFFLINE
goodnews
  • 126 Thanks
  • 423 posts
Posted May 01, 2012 - 05:42 PM
sand blasted then a coat of rust inhibtor form napa then a coat alumium oxide and then 3 coats safety red (rust oleum) with hardner from tractor supply :thumbs: God is good !!!!!!!
#88 Newpaws493 OFFLINE
Newpaws493
  • 1390 Thanks
  • 1818 posts
Posted May 01, 2012 - 08:44 PM
One day at a time 'goodnews', lookin' nice! Underside? and where's your lil' helper?
#89 goodnews OFFLINE
goodnews
  • 126 Thanks
  • 423 posts
Posted May 02, 2012 - 07:04 AM
#90 goodnews OFFLINE
goodnews
  • 126 Thanks
  • 423 posts
Posted May 02, 2012 - 07:06 AM
there is the underside same steps as the top will hand paint splindes today rom. 3:23 :thumbs:
