1054 Husky Restore
#46
OFFLINE
Posted April 05, 2012 - 12:06 AM
- goodnews said thank you
#47
OFFLINE
Posted April 05, 2012 - 04:37 AM
- Bolens 1000 and goodnews have said thanks
#48
ONLINE
Posted April 05, 2012 - 04:47 AM
Unless I missed something,that slot in the gear shift is to keep the shifter from turning.
Ok That would make sense, because the shifters are curved on the 1054 and if they were able to rotate then they would be hitting the seat when trying to shift. Since the older models used a straight shifter, It really doesn't matter if the shifter turns.
#49
OFFLINE
Posted April 07, 2012 - 12:40 PM
back to the drawing board.
#50
OFFLINE
Posted April 08, 2012 - 08:40 AM
so i guess i need some type of half moon deal , ican not find it any of the manuals and i don't think it was there when i took it apart .
Check out the parts manual at: http://gardentractor...33-bolens-1053/
Look at part # 37 and part # 117 in the diagram on page 2.
One is a roll pin and one is a dowel pin.
I suspect (but I'm not certain) that the dowel pin is held captive between the upper and lower flanges, and fits in the slot in the chassis to keep the gear shift from rotating.
The diameter of the dowel pin will probably match the width of the slot in the gearshift ball. .... The length can be easily determined.
#51
OFFLINE
Posted April 09, 2012 - 11:27 AM
thanks for everyone's help hope you all had a joyus resurrection sunday.
Edited by goodnews, April 09, 2012 - 07:12 PM.
#52
OFFLINE
Posted April 13, 2012 - 08:30 AM
Thanks 'goodnews' you've inspired me! to go for it, this is far more than tinkerin'. It shows respect to quality machines as reflected throughout GTT. Forward gear !
#53
OFFLINE
Posted April 13, 2012 - 09:27 AM
#54
ONLINE
#55
OFFLINE
Posted April 13, 2012 - 03:50 PM
2 heads are better than one . thanks in Christ goodnews
#56
OFFLINE
Posted April 13, 2012 - 04:06 PM
good afternoon 'goodnews',it seems somehow you're making replies on Newpaws thread, you might want to check your local settings...not sure how that works. All the best 2u and yours.
#57
ONLINE
#58
OFFLINE
Posted April 13, 2012 - 08:44 PM
#59
OFFLINE
Posted April 13, 2012 - 08:51 PM
Edited by goodnews, April 13, 2012 - 08:53 PM.
#60
ONLINE
Posted April 14, 2012 - 06:37 AM
