Jd 455 Lift Cylinder
1 reply to this topic
#1 Endo OFFLINE
Endo
  • 13 Thanks
  • 32 posts
Posted March 06, 2012 - 08:27 PM
My 455 has a lift cylinder that has seen better days. Anyone have any good alternatives to the OEM cylinder? Part number is AM121141.
#2 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted March 07, 2012 - 06:02 AM
The angle cylinder is the same cylinder with different fittings and hoses. If you can find a used angle cylinder you can just change over the fittings/hoses. The problem with finding a replacement is that the way the cylinder is constructed it is very short for it's 4" stroke. Do a search of surplus hydraulic suppiers and see what you can find. I'd check used GT parts suppliers and ebay etc. to see if you can find a used lift or angle cylinder.
