How Do You Run Your Hydro?
85 replies to this topic
#61 qtrhrs86 OFFLINE
qtrhrs86
  • 10 Thanks
  • 28 posts
Posted April 24, 2013 - 03:59 PM
Just like Jason Aldean, Eric Church, and Luke Bryan say: Full Throttle Wide Open     :rocker2:
#62 hatedge OFFLINE
hatedge
    Beer Guzzling Canuck
  • 292 Thanks
  • 577 posts
Posted July 08, 2013 - 02:18 PM
I tought I had answered this topic but upond reading it again I am not too sure if I did  :(
Anyway. I usually read the operator manuals for all the GTs I get. and so far its always full throttle or go to full then back down a little.
Putting around I usually go from just below 1/2 to 3/4 depending on the need for ground speed.
Up the steep hill,mowing blowing snow, rototilling I go for to full
Pulling loads 3/4 to full
When I put full throttle I always back down just a bit to like 13/16th and the engine sounds like its going smoothly on all my machines. I also respect this 13/16th for all my snowmobiles, the dune buggy and the trail bike too. the dont have hydro trannys but the engine just doesnt sound like it wants to split in two. :thumbs:
#63 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 08, 2013 - 02:41 PM
I find it depends on the Hydro. The JD314 with the sundstrand hydro is happy from about 2500 up. On the newer JD's I've had with the K series hydros they like the engine to be revved up pretty much to max. speed.
  • hatedge said thank you
#64 hatedge OFFLINE
hatedge
  • 292 Thanks
  • 577 posts
Posted July 17, 2013 - 01:30 PM
Ahhhh! well that could be true cos all the GTs I have have K series engines. Dont wanna start an argument but I think these are probably the best engines. Ive heard Wisconsin were real good but Ive never come accross one yet. Not a big fan of BS and tecumseh, but thats me  :D
Maybe I just havent been lucky but in snowmobiling kohler is also present. Being an avid antique snomobile tinkerer I tend to trust them
Edited by hatedge, July 17, 2013 - 01:33 PM.
#65 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 17, 2013 - 01:41 PM
I meant the K series hydros that JD uses. Made by Kanzaki I think, which is a division of Yanmar. The JD475 I had was a K92 transmission, the biggest one they put in GT's and it liked the engine revved up to produce good power.
#66 hatedge OFFLINE
hatedge
  • 292 Thanks
  • 577 posts
Posted July 17, 2013 - 06:02 PM
Sorry it wont happen again..... today :rolling:
#67 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 17, 2013 - 06:59 PM
I had the old JD314 out today to do a bit of box blade work. The Sundstrand transmission is perfectly happy at 2700rpms even pulling a blade.
#68 HowardsMF155 OFFLINE
  • 2,861 Thanks
  • 2,987 posts
Posted July 18, 2013 - 09:54 PM
Had my Massey (that started this thread) out mowing today.  Outside temp was about 91 F or so.  Mowed for about 1 hour, up and down some hills, mostly at slower speeds, running the motor at full throttle due to running the cutting deck.  As I was wrapping things up, I began to smell something like a hot oil smell.  I looked down and saw oil bubbling out the overflow tube (the upside down "J") .  Since I was tilted sideways at the time, with the overflow tube on the downhill side, I figured that was the issue.  However, after running the tractor back to the shed, I measured the transmission and found that the temperature was around 194 degrees F!
    So, I need to look at the cooling fan, make sure it is oriented correctly and still in good shape, and I need to make sure the brake band is releasing.  Are there any other things I should look at?
#69 HowardsMF155 OFFLINE
  • 2,861 Thanks
  • 2,987 posts
Posted July 18, 2013 - 10:41 PM
Looking for overheating information I found this, could have been useful while Tudor and I were talking about torque output and speed of a hydro vs a geared.  It came from this page, which might also be useful to some one some day:
http://service.mtdpr...S/section_6.pdf
#70 HowardsMF155 OFFLINE
  • 2,861 Thanks
  • 2,987 posts
Posted July 18, 2013 - 10:45 PM
Took a look at the situation after things had cooled off.  I currently have the brake set, which I usually do when I park the tractor.  I strongly suspect an engaged brake problem, as I haven't been able to adjust the hydro drive idler pulley to completely dis-engage when the brake is on.  I did look for that first thing, but it did appear to be dis-engaged at the time I looked.  A quick glance at the fan does not show anything wrong.
#71 hatedge OFFLINE
hatedge
  • 292 Thanks
  • 577 posts
Posted July 19, 2013 - 09:22 AM
This thread is getting even more interesting. Keep us posted on this high temp thing I am very curious as to what caused it and how to avoid the same happening to me.
#72 olcowhand ONLINE
  • 41,136 Thanks
  • 31,413 posts
Posted July 19, 2013 - 09:48 AM
Howard, from reading tech manuals, it seems the normal full op temp for most hydro's is around 185F, so you weren't all that hot really.
  • KennyP and hatedge have said thanks
#73 carolspain OFFLINE
carolspain
  • 12 Thanks
  • 14 posts
Posted August 22, 2013 - 11:05 AM
This is good info
#74 hatedge OFFLINE
hatedge
  • 292 Thanks
  • 577 posts
Posted August 23, 2013 - 11:01 PM
This is good info
It sure is, Olcow always has some good tech stuff and some very decent advice.
Edited by hatedge, August 23, 2013 - 11:02 PM.
#75 twostep ONLINE
twostep
    Rockstar
  • 1,985 Thanks
  • 2,536 posts
Posted August 26, 2013 - 01:49 PM
That is good to know... I know I would assume that that they would run similar temps as an automotive automatic trans. I assume that if the hydro has a aux port for a deck lift you could run the return through a cooler to help bring them back down.
