66 M.f 10 No Spark
13 replies to this topic
#1 ckjakline OFFLINE
ckjakline
  • 1181 Thanks
  • 1173 posts
Posted March 03, 2012 - 09:11 PM
I'm working on getting my dads 66 10 running.I bought it for him last year not running and had it running after carb cleaning and filed points.I used it for about 2 months to mow yard.The one pin for the clutch linkages worked its way out and got stuck in a hole in the frame.I havn't been able to get it running since.I read in a post in J.D. forum about lining some marks up on the flywheel when you change points.I can't find anything about changing points on the massey.Does anybody have any advice.Do the tecumseh points engines have same markings on flywheel?Any help would be appreciated.
#2 chris m OFFLINE
chris m
  • 3350 Thanks
  • 4069 posts
Posted March 03, 2012 - 09:37 PM
Not familiar with a M.F., But what engine do you have on it? Is it a HH100? (Tecumseh)
#3 DH1 OFFLINE
DH1
    Electric Tractors
  • 5495 Thanks
  • 5633 posts
The point gap is .020
The push rod that moves the points sometimes sticks, needs to be free.
If you remove the engine serial # plate, look through the hole in the shroud you can see the coil, there is a mark on the flywheel, line the two up and that is the make break timing spot for the points. Can be done with the shroud removed as well.
With the points at .020 the timing mark should be pretty close.
  • ckjakline said thank you
#4 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted March 03, 2012 - 09:45 PM
I agree with Doug, the push rod sounds as if it's sticking. I would take the points cover off & verify the motion of the points and the gap. If all looks well in there, check for a frayed wire where it leaves the points area. If this grounds out, no spark.
If that's OK, I would go around to the other side of the engine and you will find 3 wires attached to a screw on the engine tin towards the grill. One goes to the points, one in behind the tin shroud, and the third is your kill wire. I would remove that third wire from the screw, put the other two back on, and turn it over again, checking for spark. If you suddenly have spark, your switch or wire to the switch is suspect.
  • caseguy and ckjakline have said thanks
#5 johndeereelfman OFFLINE
johndeereelfman
  • 5745 Thanks
  • 2611 posts
Posted March 03, 2012 - 09:54 PM
Craig,
Is the push rod metal or fiberglass? If it's fiberglass, get yourself a 16 penny common nail, cut it to the length of the fibergalss push rod, round over the cut ends, and replace the fiberglass rod with this. Those fiberglass rods eventually absorb oil and start to swell, causing them to stick, or not slide properly. I have replaced fiberglass push rods with nails on two of my tecumseh motors, and never had a problem since.
#6 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted March 03, 2012 - 10:01 PM
If you do replace the rod with something, make sure it's soft enogh to not wear the cam. i was about to look for some brass rod or even copper nails before a member let me know of a new push rod up for auction.
#7 timtractor OFFLINE
timtractor
  • 226 Thanks
  • 376 posts
Posted March 04, 2012 - 08:59 AM
If it is not the points plunger, I would check the key in the flywheel to see if it is sheered.
#8 ckjakline OFFLINE
ckjakline
  • 1181 Thanks
  • 1173 posts
Posted March 04, 2012 - 09:54 AM
The motor is a tecumseh hh100.I already replaced the points and checked plunger.I wanted to double check if there was a way to check timing on these.It was very strange.I couldn't get spark to my spark tester,but i moved the spark plug wire a little while engine was cranking and got zapped.But it still wouldn't fire.It just seemed like it wasn't timed.I set the points to .020".I want to double check that and check wiring.Thanks for the help.
#9 HowardsMF155 OFFLINE
  • 3078 Thanks
  • 3084 posts
Posted March 04, 2012 - 10:17 AM
If you got zapped, then I would think things are working. Have you replaced your spark plug? And when you use your spark tester, is the old plug still in the spark circuit? I ask because I really went round and round with a tractor that wouldn't run, turned out it was the spark plug.
  • MH81 and ckjakline have said thanks
#10 ckjakline OFFLINE
ckjakline
  • 1181 Thanks
  • 1173 posts
Posted March 04, 2012 - 07:22 PM
I also did change spark plug.I pulled the shroud off again today.I was in the process of pulling kill wire off and got busy doing other stuff and didn't get back to it.Hopefully next weekend i can work on it some more.
#11 ckjakline OFFLINE
ckjakline
  • 1181 Thanks
  • 1173 posts
Posted July 13, 2012 - 09:36 PM
I gave up.This is the first tractor that i worked on and couldn't get it going.We took it to a small engine repair shop tonight.I havn't been able to work on it for a couple of months now.When i would get time i would get side tracked helping do other stuff.I had it in my grandfathers shop at his farm.It was definatly a stuburn one.Real spurattic.I would get spark, then it wouldn't.When i had spark i put plug back in hole and lost it.I'll have better luck next time.
#12 Wolverine OFFLINE
Wolverine
  • 13 Thanks
  • 30 posts
Posted August 02, 2012 - 04:10 PM
almost sounds like you bent your timing key. If you do that you get spark but not at top dead center and it won't fire when it's suppose too. You could have pulled the flywheel to check...
#13 ckjakline OFFLINE
ckjakline
  • 1181 Thanks
  • 1173 posts
Posted August 03, 2012 - 09:10 PM
We went and picked it up 2 weeks ago and it was a timing issue,not from the key though.I set the plug gap to .035 instead of .020.Thats what he told me anyway i know the points are .020 and spark plug is according to book it's .028.I'm not sure if he meant i had points wrong or what but he told me .020 was industry standard for plugs on small engines.I must of had my mind on my small block chevys instead of garden tractors.I figured it was something stupid but with all the interuptions and getting sidetracked with other stuff it's hard to remember where your at and where you had stuff set.On a brighter note i had the coil set up right and working.They didn't do anything to that.It runs now and only cost $18. :laughingteeth:
Edited by ckjakline, August 03, 2012 - 09:11 PM.
#14 shorty OFFLINE
shorty
  • 6031 Thanks
  • 5505 posts
Posted August 04, 2012 - 03:46 AM
I didn't know any shops work that cheap around this area any more. Last shop I went to had a sign up that it would be $50 to diagnose your problem, parts and labor on top of that. They wont be getting to much of my business at that rate, I will just do my own diagnosing.
