Bolen's Blower Part Wanted
15 replies to this topic
#1 Trent Thomson OFFLINE
Trent Thomson
  • 189 Thanks
  • 229 posts
Posted March 01, 2012 - 09:58 AM
Hey guys. I'm not sure of the model number on my blower but I think it is off an Estate keeper. I made some changes to be able to mount it on the 800. The problem is with the shoot crank. It is up front on the left hand side so I have to bend over the hood to change the direction of it. I would love to get the proper shoot and crankarm so it comes up on the right side so I could change directions from the seat. I'm quite sure the would be adaptable with a little work. Does anyone have a scraped blower and willing to sell just these parts.
#2 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,914 Thanks
  • 2,451 posts
Posted March 01, 2012 - 10:47 AM
Trent:
Can you post a pic of what you have?
What is the width of the snowblower?
#3 Trent Thomson OFFLINE
Trent Thomson
  • 189 Thanks
  • 229 posts
Posted March 01, 2012 - 01:33 PM
I'll try Bruce but it may not be till tomorrow
#4 Bolens 1000 ONLINE
  • 14,891 Thanks
  • 18,097 posts
Posted March 01, 2012 - 04:38 PM
Trent:
:ditto:
A picture would help in identifying which blower you have....
#5 Trent Thomson OFFLINE
Trent Thomson
  • 189 Thanks
  • 229 posts
Posted March 02, 2012 - 09:07 AM
Alright here goes with the pics you wanted Bruce. It is a 32 inch thrower. As you can see where the crank is now is causing scratches to the hood when I have it up. So I see a bit of painting in the future.
#6 Bolens 1000 ONLINE
  • 14,891 Thanks
  • 18,097 posts
Posted March 02, 2012 - 09:21 AM
Yeah that is definitely a older model EK Snow caster.
I believe all you would have to do is get a chute crank assembly off a tubeframe snow caster and you would be all set.
  • Trent Thomson said thank you
#7 Trent Thomson OFFLINE
Trent Thomson
  • 189 Thanks
  • 229 posts
Posted March 02, 2012 - 09:51 AM
That was what I was thinking also, but would I need the big gear on the chute and the little gear on the crank.
#8 Trent Thomson OFFLINE
Trent Thomson
  • 189 Thanks
  • 229 posts
Posted March 02, 2012 - 10:02 AM
What file was that . I can't seem to be able to find it to download
#9 Bolens 1000 ONLINE
  • 14,891 Thanks
  • 18,097 posts
Posted March 02, 2012 - 10:10 AM
http://samsbolens.co...arts_list_1.jpg
The plastic pinion Gear was the same on both models ,but I am getting different numbers on the chute housing.
Those may need to be switched as well.
#10 Trent Thomson OFFLINE
Trent Thomson
  • 189 Thanks
  • 229 posts
Posted March 02, 2012 - 02:09 PM
Any ideas about who may have what I'm after?
#11 Bolens 1000 ONLINE
  • 14,891 Thanks
  • 18,097 posts
Posted March 02, 2012 - 04:43 PM
You can check with our site sponsor Bhts
#12 Bruce Dorsi OFFLINE
Bruce Dorsi
  • 3,914 Thanks
  • 2,451 posts
Posted March 02, 2012 - 06:59 PM
Parts breakdown for the #19302 -01 & -02 Estate Keeper Sno-Caster (which appears to be what you have) is located here:
http://gardentractor...-32-sno-caster/
Parts breakdown for the (32") #18514 -01 & -02 and (36") # 18516 -01 Tube-Frame attachments is located here:
http://gardentractor...ster-partslist/
The main auger housing is the same for all of the above, but you will have to compare part numbers to see what is interchangeable, and what different parts you will need.
If you feel ambitious, you could probably shorten the shaft/crank assy that you have, and add a reversible 12v motor for remote operation of the chute rotation.
  • Bolens 1000 and Trent Thomson have said thanks
#13 Trent Thomson OFFLINE
Trent Thomson
  • 189 Thanks
  • 229 posts
Posted March 05, 2012 - 09:12 AM
Now that sounds interesting, but do you have any ideas where would I find one of those 12v motors?
#14 skyrydr2 OFFLINE
  • 3,869 Thanks
  • 3,401 posts
Posted March 05, 2012 - 11:54 AM
What a shame, I have what your looking for too, and am going to scrap it, as the auger sprocket is worn out, and it doesnt throw far enough for my drive.
#15 Bruce Dorsi OFFLINE
Bruce Dorsi
  • 3,914 Thanks
  • 2,451 posts
Posted March 05, 2012 - 02:18 PM
Trent, power window and power seat motors should have enough torque to rotate the chute, and should be available cheaply from auto salvage.
You could also try Surplus Sales (www.surplussales.com) or Surplus Center (www.surpluscenter.com) to see if they have 12vdc motors. ...You need to make sure they are reversible.
I did purchase a 12vdc reversible motor through Grainger's years ago.
