Engine (Kohler 321S) Blew, Possible Rebuild?
engine kohler 14 k321s
22 replies to this topic
#16 Cvans OFFLINE
  • 6,455 Thanks
  • 6,052 posts
Posted March 07, 2012 - 09:40 AM
If you re-installed the original rings the odds of you getting them positioned exactly as they were is about one in a million. This means that they will not seal like before as your cylinder was slightly out of round and so were the rings. You'll just have to live with a little blow-by from the breather. If you had honed the cylinder before reassembly your rings would have re-seated much better over time. Just run it until the next tear down.
  • frenchy said thank you
#17 frenchy OFFLINE
frenchy
  • 29 Thanks
  • 163 posts
Posted March 12, 2012 - 11:11 AM
Thanks Cvans and JDBrian. I've been sick for the past 5 days, so i'm hoping to get the governor adjusted this week. Crappy part is that there will be no need to clear snow as the forecast is calling for mid-teens (celsius) this week! Oh well, I need the blade to move some gravel this spring anyways!
#18 frenchy OFFLINE
frenchy
  • 29 Thanks
  • 163 posts
Posted March 15, 2012 - 12:05 PM
Ok here's the topic closer....
Problem: Hole busted out side of engine
Diagnosis: Balance gear needle bearing failure
Remediation: Remove engine, dissasemble, remove balance gears, clean all parts, patch casing hole with leftover piece of casing and JB Weld, reassemble engine, re-mount engine, change all fuel lines, adjust governer and all is peachy!
thanks all who contributed, you have save me money that I couldn't afford to spend on a new engine or tractor!
Frenchy
#19 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 15, 2012 - 01:16 PM
Any size hole is fixable, well, most of the time. :-)
  • JDBrian said thank you
#20 JDBrian OFFLINE
  • 9,601 Thanks
Posted March 18, 2012 - 07:07 AM
Man that was a huge blowout in the side of that case. Someone did a super job of welding up that cast!!
#21 frenchy OFFLINE
frenchy
  • 29 Thanks
  • 163 posts
Posted March 19, 2012 - 12:17 PM
For inquiring minds, here's a video of the Kohler running (prior to adjusting the governor)
#22 KennyP ONLINE
  • 37,426 Thanks
  • 45,465 posts
Posted March 20, 2012 - 06:01 AM
Glad you got it going again. Thanks for the video.
#23 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted March 26, 2012 - 03:12 PM
ya know what they say when a kohler blows a kohler blows
Also tagged with one or more of these keywords: engine, kohler 14 k321s
