Bolens 775
21 replies to this topic
#16 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted March 01, 2012 - 04:45 PM
Yea i think i have a set of the weights
If you dont mind could you snap a pic or two of them Bob?
#17 shinklem OFFLINE
shinklem
  • 3 Thanks
  • 27 posts
Posted March 01, 2012 - 06:38 PM
Hello all, Well, my better judgement kicked in (rare, but sometimes it does happen) and decided to pass on the 775.Need to focus on some of my other ump-teen projects. but at least it looks like i sparked a good discussion on the wheel weights for these little guys. and once again KUDOS to all of you at GT talk. You make this hobby alot more enjoyable for a novice like myself.
#18 bhts OFFLINE
bhts
    Bob's Lawn and Garden LLC
  • 1493 Thanks
  • 2181 posts
Posted March 01, 2012 - 07:18 PM
Sorry Doc i made a booboo the ones i have i belive are for the small frames and not the 775.
#19 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted March 02, 2012 - 08:51 AM
My Attachment Chart shows two "Small Frames".
One is listed as SMALL (STAMPED) FRAME TRACTOR which are listed as the 510, 610, 613, 813, G8, LT8, LT8E, and LT11.
The weights listed are 15105 and 15116 and are 70# Pr.
The other is just SMALL FRAME TRACTOR which is listed as the 770, 775, 730, 733, and 736.
The weights listed for those are 18012 again 70# Pr.
I looked through the whole list, and the EK and LK series are the ONLY ones that didn't have wheel weights available. However there is a rear weight (19305) listed for the EKs.
  • Bolens800uk said thank you
#20 Drgfreelife98 OFFLINE
Drgfreelife98
  • 2 Thanks
  • 3 posts
Posted May 05, 2018 - 04:41 AM
#21 Drgfreelife98 OFFLINE
Drgfreelife98
  • 2 Thanks
  • 3 posts
Posted May 05, 2018 - 04:43 AM
Very old convo here. But do you have or know of anything I could buy for my 775
166-02?
#22 chieffan ONLINE
  • 16622 Thanks
  • 9094 posts
Posted May 06, 2018 - 07:24 AM
I picked up a 775 about a year ago.  Got the deck, front blade and snow thrower with it.  Had the thrower mounted when I picked it up.  GF uses it as her yard donkey as the tunnel is an easy step over for her bad hips.  Have had no problem with it.  Engine has an oil leak but can't blame the tractor for that.  Need a picture of the deck lift brackets as the ones one it are put together wrong and won't mount up.  Want to use it for mowing around in the tighter areas where the big decks won't go.
  • Bolens800uk and logmillingman have said thanks
