Busy Busy Day
18 replies to this topic
#1 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted February 26, 2012 - 08:38 PM
went out to the shop at 9;00 am and finished the boat trailer tongue and the wiring and pulled it out . pushed the 112 out of the corner and messed with it for a few hours and it would not start so i went fishing in the lake behind the house for a couple of hours . wasn't catching any fish so i went back to the 112 and for some reason it only has a spark when i let off the key . when your cranking the engine it has no spark and not sure why but it did start and i took it a few laps around the yard and then it died dead again . this thing needs a lot of TLC it has a very bad oil leak im not sure how im going to fix the hood yet the choke cable gas line are not in the proper place wires just ran every where ( AAHHHGGGG ) .
#2 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted February 26, 2012 - 08:40 PM
Sounds like a bad ground Gary.
#3 olcowhand ONLINE
  • 41,103 Thanks
  • 31,404 posts
Posted February 26, 2012 - 08:43 PM
Is this a Kohler or TEC engine? I'm not that familiar with JD models.
#4 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted February 26, 2012 - 08:48 PM
Is this the tractor model and type ?
How may we help you ? lots of JD guys here.
#5 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
i thought that also and it is not charging and im sure it the wires coming from the stater as i can see the insulation is bad on the wires . i think ill try to find a good wiring harness and start there .
#6 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted February 26, 2012 - 08:55 PM
no its this type
http://gardentractor...ll-i-bought-it/
  • trowel said thank you
#7 Texas Deere and Horse ONLINE
  • 14,800 Thanks
  • 15,495 posts
Posted February 26, 2012 - 08:57 PM
Gary, It could be a bad ignition switch not giving power to the coil in start mode. I have had that issue before.
  • Gary400 said thank you
#8 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted February 26, 2012 - 09:05 PM
it has a kohler , they told me when i picked it up that it had been rebuilt last year and it does run very good when i get it started . i kinda have my doubts about that, it is very dirty and there are many bolts that have never been taking off the engine .
#9 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted February 26, 2012 - 09:14 PM
Sometimes people call a simple overhaul or daily maintenance a rebuild, we do live in a close-minded society regarding all things mechanical nowadays, have ran into that problem many times.
Just a thought or two.
  • chris m said thank you
#10 olcowhand ONLINE
  • 41,103 Thanks
  • 31,404 posts
Posted February 26, 2012 - 09:18 PM
May be simply the ignition key switch bad, or may be the wrong one completely. Some universal key switches will cut off the ignition pole during cranking. For this type, you need a Ford (car) starter solenoid with 4 poles. 2 poles for the large battery cables, the one little pole for "start", and the 2nd little pole that sends juice to the coil during cranking.
#11 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted February 26, 2012 - 09:19 PM
I love that line " it was rebuilt last year" but you look at the engine and it looks like it was pulled up from the titanic <_< Next time someone says this and it looks bad, say "last year? you mean the last year Nixon was in office?"
#12 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted February 26, 2012 - 09:21 PM
Yea see, right there. Look closer, that is a new wing nut on there! see I rebuilt it.
#13 olcowhand ONLINE
  • 41,103 Thanks
  • 31,404 posts
Posted February 26, 2012 - 09:24 PM
And it's a chrome wing nut to boot, so it's a "custom rebuilt" engine! :bigrofl:
  • trowel and chris m have said thanks
#14 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted February 26, 2012 - 09:35 PM
If this thing looks as bad as you are describing it, then it might just be a bad connection. Just disconnect the battery and start cleaning all connections! 90% of the time it's a bad connection versus a bad component, Just take your time and don't get stressed out thinking you need to replace the entire harness and a bunch of components. start with the easy 1st! (process of elimination) Good luck!
#15 mjodrey OFFLINE
Posted February 27, 2012 - 07:55 AM
I was also thinking that it may be a bad ignition switch.
