T70B Full Restoration, Pic Extensive!
144 replies to this topic
#121 DirtyContacts OFFLINE
DirtyContacts
  • 19 Thanks
  • 79 posts
Posted July 25, 2013 - 11:51 AM
Hey Guys, I had to set up a new name on here since the site wouldn't send me a new password.  As you can see I only dropped the S on the name.  Im going to be reserrecting this thread.
Its been about a year since I did any work on the Panzer, till now.  I was at the hardware store the other day and found the small collars that go on the foot rest bar.  Hoping to pull the tractor out tonight and start working again.  So now its time to finish the build.
Ill post some pics tonight of the tractor as she sits.
#122 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted July 25, 2013 - 07:49 PM
I merged your old account with the new one. If you would prefer to have the s at the end send me a pm and I can adjust it for you.
  • DirtyContacts said thank you
#123 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted July 25, 2013 - 09:41 PM
10:40 and still no pics  :ah_shoot:
  • JohnD. said thank you
#124 DirtyContacts OFFLINE
DirtyContacts
  • 19 Thanks
  • 79 posts
Posted July 26, 2013 - 08:14 AM
Sorry guys, I was beat last night I fell asleep at 8pm.  I will be sure to load a few pics tonight.
#125 DirtyContacts OFFLINE
DirtyContacts
  • 19 Thanks
  • 79 posts
Posted July 26, 2013 - 07:38 PM
Ok, as promised im going to post some pics of the tractor.  I have finally accumulated enough parts to finish this project.  here we go enjoy!!
Im starting of with a set of tires I found, these are a set of Firestone tires pretty close to original.
Here is a shot of the transmission lever, completely rebuilt.  all bolts were replace with zinc dichromate CAT bolts.  The foot pedal was textured for an added look.
Here is the 3/4 inch ID collars that will secure the transmission lever in place, im waiting for 2 more to come in so I can use all 8 as it was originally.  This is also going to hold the foot rest bar in place.  I bought a new foot rest bar from my local Lowes.  Its a 3/4 inch thick bar that will be cut down to size as the next step in the build.
The Panzer has sat in the back of my garage for a year till today,  Oh, the dust!!
This is one of my favorite shots!
Alright guys and gals, feel free to ask questions and or make suggestions.   My goal for this tractor is to be a parade tractor, where I live we have a large parade for the 4th of July, she will no longer have to work but more for show.  I have another year before the next parade, I think this is enough time.
  • chris m and JohnD. have said thanks
#126 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted July 26, 2013 - 08:26 PM
Glad to see you are back at it!! It is all looking great so far! Good luck :thumbs:
#127 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted July 26, 2013 - 09:47 PM
f
f
fantastic.
I see the chips in the paint of mine and sometimes wish I'd built it just for show.  Maybe someday when I have a big enough place for 2!
#128 DirtyContacts OFFLINE
DirtyContacts
  • 19 Thanks
  • 79 posts
Posted July 27, 2013 - 06:11 AM
Thanks guys, I cant wait to get going again, took all the parts that had laying arouns and if it wasnt for those damn collars I think it would have been finished a long time ago.
#129 suburban 12 OFFLINE
suburban 12
  • 396 Thanks
  • 325 posts
Posted July 28, 2013 - 08:38 PM
The Tractor Supply by me has new tires that are even closer to the original tire tread.
#130 DirtyContacts OFFLINE
DirtyContacts
  • 19 Thanks
  • 79 posts
Posted July 31, 2013 - 11:47 AM
Ok guys, I need help, with my tires.  How do ya'll get the tires off the rims?  I have done it on regular lawn tires but the small fronts on the Panzer are being a bugger to get off.  Any advise will be greatly appreciated.
#131 BowDown OFFLINE
BowDown
  • 551 Thanks
  • 562 posts
Posted July 31, 2013 - 01:47 PM
If in doubt just cut off the old ones. You bought new tubes right?
#132 suburban 12 OFFLINE
suburban 12
  • 396 Thanks
  • 325 posts
Posted July 31, 2013 - 01:51 PM
For mine, I took the blots out of the so that the rim could come apart. Mine were in rough shape, so I cut them in half, knocked the rim apart and went from there. I used a screwdriver to get in and pry on the bead, after a little bit of work they just slid off.
#133 DirtyContacts OFFLINE
DirtyContacts
  • 19 Thanks
  • 79 posts
Posted July 31, 2013 - 03:13 PM
I only have 1 piece front rims on my 62 Panzer, I had 2 peice on my 66 Panzer.
#134 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted July 31, 2013 - 03:42 PM
The small ones can be tough and more so if they are old and hard. Once the bead is broken I use two tire spoons,  If you put the rim in front of you on the floor, and put 1 knee on the tire (part right in front of you, 6'oclock) to kind of compress that area, at the same time put a spoon on the opposite side (top, 12 o'clock) and pull the spoon to lift the bead out of the rim, now put a second spoon about an inch to either side of the first and pry that one back. while doing this push the 6'oclock side of the tire in to the center of the rim to give you as much slack as you can. once you get it started it will go easier. The second side will come of a lot easier. Just be sure the bead is broke( not seated) on both sides before trying to remove them.
Also if you are scrapping the tires, once you get the one side off the rim it will make cutting the tire off a little easier.
I hope this helps as it is a little hard to explain it. ( for me anyway)
Good luck!
#135 DirtyContacts OFFLINE
DirtyContacts
  • 19 Thanks
  • 79 posts
Posted August 01, 2013 - 08:48 AM
I need to get the tubes but I wanted to pain the new rims.
Thank you Chris M, I will try this tonight!
