3 Hp Briggs Cam Timing
10 replies to this topic
#1 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted February 26, 2012 - 06:08 PM
well im starting to put together the 3 hp briggs project. But i ran into a little problem. There are no timing mark on the cam drive gear. I didnt notice this before i took it apart. any idea of how to time it
#2 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted February 26, 2012 - 06:13 PM
http://www.youtube.c...e&v=tS5h0cVbL_w
http://www.google.co...ll8WgYgIEK74BfQ
Edited by trowel, February 26, 2012 - 06:14 PM.
  • caseguy, 1978murray, Toolpartzman and 1 other said thanks
#3 caseguy OFFLINE
  • 1,627 Thanks
Posted February 26, 2012 - 07:03 PM
Thanks Trowel! That video makes it so easy a caveman could do it! I might even be able to figure it out! Reply #2 on the second link tells what to do if you can't find the marks. Very thorough reply!
  • trowel said thank you
#4 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted February 26, 2012 - 07:31 PM
Thanks, i try my best to be thorough, staightforwards and make it easy for everyone,
Less typing for me to do too :thumbs:
  • chris m said thank you
#5 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted February 26, 2012 - 08:33 PM
I just saw a caveman and boy is he mad cause he still can't do it! :smilewink:
#6 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted February 26, 2012 - 08:41 PM
Kind of like that geico commercial " so easy a caveman can do it "........(frustrated caveman stuggling with camshaft in background)
#7 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted February 28, 2012 - 02:59 PM
looked for marks there are no factory timming marks. When i got this engine the timing was to advanced. Idk how to time without marks
#8 caseguy OFFLINE
  • 1,627 Thanks
Posted February 28, 2012 - 09:06 PM
In the second post of the second link that trowel posted above were directions for timing without the marks. It's short, but simple:
...bring the piston to top dead center with magnet on flywheel at coil, set cam with both valves closed. done.
#9 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted February 29, 2012 - 04:41 PM
yea but that doesnt say wat valve opens first. or where to put the cam. both closed could mean any number or timing
#10 MH81 OFFLINE
Posted March 02, 2012 - 09:35 PM
Maybe this video will help.
If you study the operation, the answer should be a little more evident.
Hope that helps.
#11 DougT ONLINE
DougT
    Dog Approved
  • 6,846 Thanks
  • 4,948 posts
Posted March 03, 2012 - 07:20 PM
Most of the stuff I work on doesn't have timing marks. The way I time an engine is to watch the exhaust valve while turning the engine in the direction of rotation. It should fully close as the piston goes past top dead center. The intake valve should open at about the same time or shortly after as the piston starts down. The intake valve should close before the piston gets to the bottom. The next stroke up will be compression with ignition happening near TDC. As the piston goes down on the power stroke, the exhaust valve should open before it gets to bottom dead center. I tend to time more off the closing of the exhaust valve than the other positions but sometimes I'll move it a tooth either way and see what looks best. Just always make sure your turning it in the direction of rotation.
  • caseguy said thank you
