I used 2 pieces of heavy 5x6 angle iron to bolt to the axle clamps.
The next step was to lay out another piece of angle iron to make the anchor point for the 3 point hitch arms.
I made this piece so it bolts to the large angle irons.
The bracket for the upper link is bolted to the top of the heavy angle iron.
I made a pair of stabilizer bars that bolt to the lift arms to prevent the drawbar from swaying.
I have the hitch made enough to try it out and see if what I have made so far works the way I want it to. The rest of the hydrauliclift parts will have to wait for awhile but I want to test this out for now and see if I need to make any changes in it.
This will be a catagory 1 three point hitch, good for about 50 horse power. The Farmall H is only 28 horse power. By using a Cat 1 hitch any implement made to work with Ford N series will work.
I bought the arms, drawbar, and upper stabilizer bars. So far I have about $125.00 into it.
