Got The 1855 Home Last Night. 5 Pictures.
21 replies to this topic
#1 MNrivergardener OFFLINE
MNrivergardener
  • 2 Thanks
  • 13 posts
Posted February 25, 2012 - 08:28 PM
Hey,
Along with the tractor I got a brouchure, a black and white unused Oval Snapper sticker, a box of misc. small metal parts and shims, a 3pt tool with a ball hitch, and a new front spare tire, and a set of 3 brand new mower blades wrapped in tape un-installed. The only thing's that I see that are wrong with it is that it has a small oil leak from around the main bottem engine gasket ( the gasket from where the top half of the engine block meets the bottem half by the crank ) and one of the headlights is burnt out. engine starts with ease, idels, hi/low trans. works great. hydraulic lifts for tiller and deck worrk good. front and rear pto's work as expected. this is a really huge garden tractor! I just have a few questions.
1) Is the hydro fluid ATF ? Thats sure what it looks like. In my 316 I had just used NAPA " Heavy Equiptment and Tractor Hydraulic Fluid "
2) What would you recomend for engine oil? With my 316 I just used Castrol heavy duty 30w
Thanks!
Travis
#2 ckjakline OFFLINE
ckjakline
  • 1192 Thanks
  • 1177 posts
Posted February 25, 2012 - 08:37 PM
Nice looking tractor.Thats a huge tiller!
#3 chris m OFFLINE
chris m
  • 3350 Thanks
  • 4069 posts
Posted February 25, 2012 - 08:40 PM
Great looking GT! And I agree that's a huge tiller! Good luck with it! I am sure someone will come on soon that knows more about these.
#4 caseguy OFFLINE
  • 1635 Thanks
  • 5600 posts
I can't answer any of your questions, but that sure looks like a nice score! Those things are huge!
#5 tractormike OFFLINE
tractormike
  • 179 Thanks
  • 1488 posts
NICE looking tractor you found. I think you will be happy with it, they are heavy duty and BIG as you found out. I have 2 1650's and really like the foot controlled hydro and the hydraulic lift for the attachments. I believe the hydros used tranny fluid, that is what was in mine when I got them. As to the engine oil you should be fine with the 30W. Congrats on your new work horse!
#6 ducky OFFLINE
  • 2375 Thanks
  • 4342 posts
Posted February 25, 2012 - 08:46 PM
Travis, you have one hell of a nice tractor there. They are tough and get to job done.
#7 NUTNDUN OFFLINE
  • 10456 Thanks
  • 15622 posts
Posted February 25, 2012 - 08:52 PM
The Snapper and Massey 1650 - 1855 are a good sized garden tractor. They are basically just as big as what some of the compact utility tractors are. I would love to find a tiller like that when I have some extra cash sometime.
They already answered your oil questions. Regarding the oil leak, check the dip stick tube going in to the block to see if it might be leaking in that area. The Snapper 1655 I sold leaked down where the dip stick tube went in to the block. Here the o-ring was dried up and half missing. I got a new o-ring for it and it didn't leak anymore.
#8 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1295 Thanks
  • 1443 posts
Posted February 25, 2012 - 08:56 PM
Wow,nice looking rig Travis!
#9 jimbobbillyray OFFLINE
jimbobbillyray
  • 3252 Thanks
  • 2967 posts
Posted February 25, 2012 - 09:00 PM
Wow. Nice find! Thanks for posting pics!
#10 ErnRemy OFFLINE
ErnRemy
  • 21 Thanks
  • 153 posts
Posted February 25, 2012 - 09:08 PM
She looks good, for the engine oil it depends on the weather conditions that you intend to run the tractor for hotter days you should run 30w but a good 10w30 would work well in most conditions. For the tranny/hydro again depending on the weather and wear of the hydro you might have to run 30w motor oil. Most times atf will work quite well. You might consider building a front weight carrier when using the tiller they wiegh a tonne out the back and you lose steering. Will you be looking for a snow blower in the future? They are hard to find for the front pto drives like we have. Have a look at what I did to mine for a snowblower , I have mixed feelings about my blower this year i have been looking forward to using it lots but have only moved snow twice this year . I also really beefed up the drive system with out putting extra wear on the front/flywheel side of the engine.
#11 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted February 25, 2012 - 09:43 PM
You can use Dexron III in the hydro. Yes, you choice of engine oil should do fine, & is the factory recommended weight. That's one nice looking outfit!
#12 daytime dave OFFLINE
  • 5488 Thanks
  • 6781 posts
Posted February 25, 2012 - 11:48 PM
Very nice looking Snapper. That tiller is killer. Congrats on a great deal.
#13 KennyP ONLINE
  • 53159 Thanks
  • 53302 posts
Posted February 26, 2012 - 05:24 AM
Nice tractor and tiller. You should get lots of use out of it. Thanks for the pics, guys.
#14 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 26, 2012 - 05:41 AM
Good looking tractor. You'll enjoy the foot pedal hydro.
#15 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted February 26, 2012 - 07:22 AM
Travis,very nice looking tractor.
