Restoration Of My David Bradley Implements
26 replies to this topic
#16 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted April 22, 2012 - 10:30 AM
You need to get that paint off the face of the plow, its holding you back. Find some sand and plow though that for a while. For virgin ground like that you might have to get one weight on the right and a pair on the left side.
#17 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted April 22, 2012 - 07:00 PM
I don't plan on plowing with it that often, I will be plowing at a Tractor show in June. This was just a test to see if will work. The bottom edge of the plow share is worn down abd needs to be built up.
As far as weights, unless I can find some close by that are cheap, I would fill the tires first, I could probably add 50-100 lbs easy with just washer fluid.
#18 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted April 28, 2012 - 07:41 PM
The Disc and Cultivator are finished.
Edited by Amigatec, April 28, 2012 - 07:41 PM.
#19 Alc ONLINE
  • 6,903 Thanks
  • 7,468 posts
Posted April 28, 2012 - 08:43 PM
Thanks for the update video !
#20 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted May 01, 2012 - 06:39 AM
The DB and all the implements are finished!!
#21 KennyP ONLINE
  • 38,453 Thanks
  • 45,965 posts
Posted May 01, 2012 - 06:51 AM
Looking good! Thanks for the video!
#22 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted May 01, 2012 - 12:02 PM
Show us a picture of why you think the plow share is worn across the bottom edge.
#23 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted May 01, 2012 - 05:10 PM
If you look at the back side where the 'suck' is you will see it doesn't have any. The point looks good but the suck is gone.
#24 Alc ONLINE
  • 6,903 Thanks
  • 7,468 posts
Posted May 01, 2012 - 07:59 PM
Your tractor and attachments look great ! Thanks for sharing the video with us , Al
#25 KennyP ONLINE
  • 38,453 Thanks
  • 45,965 posts
Posted May 02, 2012 - 05:34 AM
I think that is what is wrong with my plow, looks very similar at the point. It just wouldn't start digging in. Haven't had a chance to try it again.
#26 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted May 02, 2012 - 05:53 AM
I need to weld up the bottom of the share point so it points down, it looks good on the front side, but on the landslide side it is worn down.
#27 KennyP ONLINE
  • 38,453 Thanks
  • 45,965 posts
Posted May 02, 2012 - 06:04 AM
I'm following along on this. I had thought about doing that to mine!
