Sears / David Bradley 725
sears david bradley 725
39 replies to this topic
#31 trowel OFFLINE
trowel
    Summer.
  • 4,822 Thanks
  • 4,533 posts
Posted March 31, 2012 - 06:20 PM
I'm sure you were giggling like a schoolgirl in that video and edited the sound out to avoid embarrassment, too late. :bigrofl:
:bigrofl: :bigrofl: :bigrofl:
By the way :tractor_rocks:
#32 caseguy OFFLINE
Posted March 31, 2012 - 07:29 PM
Glad that you got it running! Looking better all the time! ...so is that one gonna be at plow day?
#33 MH81 ONLINE
  • 29,900 Thanks
  • 29,729 posts
Posted March 31, 2012 - 07:32 PM
Maybe ours, if I can get the belts and idle fine tuned.
#34 tractorman604 OFFLINE
tractorman604
  • 269 Thanks
  • 694 posts
Posted March 31, 2012 - 07:37 PM
You fella's must have all those david bradley's over there. There sure aren't any around Ontario that i've seen. :mecry:
#35 MH81 ONLINE
  • 29,900 Thanks
  • 29,729 posts
Posted April 22, 2012 - 06:31 PM
I finished making the adapter for the 3 point hitch. Then guess what I did???
:dancingbanana: :dancingbanana: :dancingbanana: :dancingbanana: :dancingbanana: :dancingbanana: :dancingbanana:
No weight added (below the seat, that is...) no chains and it was sprinkling.
Wheels did spin, but I could plow. Whahooo!
I do have a set of chains and a pair of solid steel pcs that weigh 50# each for weight.
This will take a little getting used to with the hand clutch and vari-speed, but it's kinda fun to drive.
#36 caseguy OFFLINE
Posted April 22, 2012 - 06:35 PM
WooHoo! :dancingbanana: :yelclap: :dancingbanana: :yelclap: :dancingbanana: :yelclap: :dancingbanana:
#37 KennyP ONLINE
  • 34,194 Thanks
  • 43,320 posts
Posted April 22, 2012 - 07:06 PM
Way to go, Alan! Before long you won't have to worry about mowing, you'll have it all plowed under. :bigrofl:
#38 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,475 Thanks
  • 2,811 posts
Posted April 22, 2012 - 07:29 PM
nice, very nice. Your sub must be a 633, or 634. Imagine how must better it would pull with some ag tires on it!!!
Its too hard to master the hand clutch, run the 3pt handle, maybe move the vari-speed, and then a little throttle. Oh ya you got to steer once in a while too. You'll learn to use you knee for steering.
Looks like you got some rocks growing there, hate to see that.
#39 MH81 ONLINE
  • 29,900 Thanks
  • 29,729 posts
Posted April 29, 2012 - 05:43 AM
Ran the 725 at plow day a little. It worked pretty well. 2 problems, the governor seems slow to respond and the 3 point arms have just enough slop to cause some tracking issues with the plow. A couple of washers strategically placed and it was much better, but I think i'll redo the arm bushings instead of spacing them over.
#40 MH81 ONLINE
  • 29,900 Thanks
  • 29,729 posts
Posted April 29, 2012 - 05:45 AM
Its too hard to master the hand clutch, run the 3pt handle, maybe move the vari-speed, and then a little throttle. Oh ya you got to steer once in a while too. You'll learn to use your knee for steering.
I told Dad I would need to grow some extra appendages if this was a daily user. :)
Also tagged with one or more of these keywords: sears, david bradley, 725
