Massey "2050", Customized MF1650
22 replies to this topic
#16 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted May 06, 2012 - 09:07 PM
What an awesome build!!!!!! Thanks for digging this up for me Daniel!!. I'm going to go back to drooling over the pictures :p
#17 Texas Deere and Horse OFFLINE
  • 14,792 Thanks
  • 15,492 posts
Posted May 06, 2012 - 09:43 PM
Daniel, Thanks for bringing this up. I had never read the build thread either.
#18 KennyP ONLINE
  • 38,172 Thanks
  • 45,835 posts
Posted May 07, 2012 - 02:02 AM
Great thread, Daniel! Glad you were able to shoehorn that Onan in there! Nice custom touches you've added!
#19 bigcountryguy OFFLINE
bigcountryguy
  • 2 Thanks
  • 3 posts
Posted June 01, 2012 - 01:11 AM
nice worksmanship. looks truely factory made
#20 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted July 12, 2012 - 11:39 PM
I've run into a similar problem with the repower on my MF7 with the 9 hp Tecumseh OHV. I'm thinking of moving the battery to the front of the engine compartment so I can put a fuel tank where the battery used to go. I wish I had a TIG setup as it would be easier to build a tank than it has been to find something that will fit.
#21 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted July 12, 2012 - 11:40 PM
The 3rd addition was power steering. I bought a PS Valve body with short column and welded in bracket to hold it. Was a challenge getting hose routing inside the narrow MF14 dash. The cylinder I used for the steering is the mid mount mower lift cylinder from the MF14. I lathed a new cylinder body end cap & fitted an eye joint to it, and on shaft end simply screwed on a heim joint. At first I retained the bell crank under the engine, but having too many joints created too much play in the system, so I added a bracket in front of the axle beam so I could connect cylinder direct to the spindle control arm.
Daniel
What did the Steering Wheel and valve cost you? I want to put power steering in whatever tractor I abuild a loader for, but the prices I've seen tend to hit close to half a G-note.
#22 olcowhand ONLINE
  • 41,004 Thanks
  • 31,367 posts
Posted July 13, 2012 - 08:52 AM
Daniel
That was several years ago & my memory fades. But I think I gave around $100 for the steering valve with stub column & wheel, then about $50 for the cylinder. Today the prices can get lots higher though.
#23 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted July 13, 2012 - 09:04 AM
This is fantastic! Wasn't around when it started, so never saw it till now.
Truly great cusomizations
