Bolens Front End Wieghts
42 replies to this topic
#16 Guest_tgguy1122_*
Guest_tgguy1122_*
  • Guests
Posted February 25, 2012 - 09:17 AM
the fronts narrower by about an inch.
  • Bruce Dorsi said thank you
#17 Dons916 OFFLINE
Dons916
  • 26 posts
Posted February 25, 2012 - 12:55 PM
The plow I have has been cut off just in front of the cutting disk and a 2" angle welded on with pins for the 3pt.
#18 Dons916 OFFLINE
Dons916
  • 26 posts
Posted February 25, 2012 - 01:00 PM
After looking at the hood of the tractor think I can just make it removable instead of tilting.Then I can attatch the box.
#19 jimbobbillyray OFFLINE
jimbobbillyray
  • 3252 Thanks
  • 2967 posts
Posted February 25, 2012 - 01:58 PM
Bolens never had a front weight box... They used a brinly dump that attached to the rear , thats probably what you are thinking about.
Ain't the first time I have been wrong. Thanks for straightening me out on that. I know i have seen one mounted on the front, but it must have not been for a Bolens.
#20 Guest_tgguy1122_*
Guest_tgguy1122_*
  • Guests
Posted February 25, 2012 - 02:16 PM
it might have been on here i was reading a sears thread about a box that hooked up to the front. cept it was a rectangle not like a little wheelbarrel.
#21 jimbobbillyray OFFLINE
jimbobbillyray
  • 3252 Thanks
  • 2967 posts
Posted February 25, 2012 - 03:49 PM
I remember seeing that too, either here or another forum. Probably what I was thinking of.
#22 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted February 25, 2012 - 04:09 PM
Yeah, that was mine. I'm still trying to figure out what Sears it bolted to, but I have started gathering steel for the new mount construction.
#23 redcarkids OFFLINE
redcarkids
  • 246 Thanks
  • 470 posts
Posted February 25, 2012 - 05:28 PM
Could a home made y type hitch off the front work and just put regular barbell lifting weights on the post sticking out the front work for Don? He would not have to mess with the hood at all and the hitch would attache to the front where the blower would.
I can see it in my head but can't describe it very well. Welcome to the jungle Don someone will figure it out for you.
#24 redcarkids OFFLINE
redcarkids
  • 246 Thanks
  • 470 posts
Posted February 25, 2012 - 05:31 PM
I think you would be better off finding some front weights for plowing.
never seen or heard of these before. i bet they are expensive if they are rare to come by.
#25 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted February 25, 2012 - 05:39 PM
Are you referring to the front weights or the Brinly dump?
#26 redcarkids OFFLINE
redcarkids
  • 246 Thanks
  • 470 posts
Posted February 25, 2012 - 05:42 PM
front wheel weights. do you have a set?
#27 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted February 25, 2012 - 05:48 PM
Yeah, I got them for free a couple years ago :D
Before and after
#28 Guest_tgguy1122_*
Guest_tgguy1122_*
  • Guests
Posted February 25, 2012 - 05:55 PM
those sure are nice
#29 timtractor OFFLINE
timtractor
  • 226 Thanks
  • 376 posts
Is the front axle mounting the same as a 1250?
#30 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted February 25, 2012 - 05:56 PM
Doc, I'm pretty sure you overpaid. I'm certain several people here would help you out by buying them for what you have in them.
Nice looking weights! What do you have them on?
