Got This One Last Week
12 replies to this topic
#1 inkman232001 OFFLINE
inkman232001
  • 16 Thanks
  • 59 posts
Posted February 22, 2012 - 01:24 PM
I dont know to much about this model, all i know is alot of the parts will work on my allis if i need them. Any info on this would be nice. thanks
#2 mjodrey OFFLINE
  • 2,356 Thanks
Posted February 22, 2012 - 01:28 PM
What is that,about a '68 or so ?
#3 MH81 OFFLINE
Posted February 22, 2012 - 01:32 PM
Very Similar to the b112 with variable speed. Nice unit, but the variator on it is a little unneccessary.
#4 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted February 22, 2012 - 03:05 PM
Nice tractor. Probably a '69 or '70 model and the Allis-Chalmers equivalent would be the B-210.
#5 daytime dave OFFLINE
  • 4,845 Thanks
  • 6,545 posts
Posted February 22, 2012 - 04:30 PM
Looks to be in decent shape.
#6 inkman232001 OFFLINE
inkman232001
  • 16 Thanks
  • 59 posts
Posted February 22, 2012 - 05:06 PM
ya its not in bad shape at all, i found the operators & parts manual online for free to download. The only major problem I have is finding a carberator for it, the one that came with it , the valve hole in the bowl is striped. Other then that its in decent shape. Everything is tight on the tractor and still has the original muffler on it. The story i got with it was that an old man owned it and kept it in his barn, then he died and his son was going to restore it and all he got around to doing was buying the carb rebuild kit. I paid 300 for it but only cause like i said everything on the tractor is nice and tight like the gear box when you shift it, and the steering has no play in it at all. Also need the side pannels but thats about it. It will make a nice project once i get around to it.
#7 Ryan313 OFFLINE
  • 3,369 Thanks
  • 5,231 posts
Posted February 22, 2012 - 07:56 PM
Looks like a winner! Seems to be in good overall condition!
#8 NUTNDUN OFFLINE
  • 10,340 Thanks
Posted February 22, 2012 - 09:16 PM
That Simplicity looks to be in very nice shape and $300 is a great deal for it. I don't know much about the Simplicitys but I really like the looks of them. You should be able to get a carb pretty easy for it if you know the make and model of the engine. Check with one of the site sponsors or ebay.
#9 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted February 22, 2012 - 10:07 PM
That is a great deal! I have a couple parts landlords at the house.....looked at a few local that wanted close to what you paid and were in pretty poor shape. Great find!
#10 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted February 22, 2012 - 11:41 PM
Oh, hey, there's something you don't see very often, very nice looking, thoses and the Alice are up there with the Cubs for that time, vey well build and uses the same gearbox as what's in the walk behind tractors, the W models if i remember right, tough, well built gearbox, i want that tractor but keep missing it.
#11 Texas Deere and Horse OFFLINE
  • 14,814 Thanks
  • 15,501 posts
Posted February 23, 2012 - 12:53 AM
1970 LANDLORD - 10 hp. Engine Briggs & Stratton 4-cycle air-cooled single-cylinder. 10 hp., 23.94 cu. in. displacement. Stellite exhaust valve and seat. Horizontal crankshaft. Cast iron construction. Fuel capacity 6 qts. Starting Easy-Spin 12 volt electric starter/ generator with 40 ampere-hour battery, 3-stage voltage regulator. Key ignition switch with neutral interlock to prevent starting in gear. Transmission Variable Speed Drive unit has 3 forward ranges, 1 reverse, permits instant changes in ground speed without shifting or changing attachment speed. Speeds Variable Speed Drive: .8 to 6.1 mph. forward, to 3.14 mph. in reverse. Rear Axle Controlled Traction Differential, combining true differential action with limited-slip traction. Frame Electrically welded heavy gauge frame. Inverted channel construction permits low mounting of large engine for low center of gravity. Power Take-off Three. At front, center and rear. Operate independently of vehicle drive. Clutch-brake On one pedal. Top of travel declutches, further travel controls brake. Separate lock provides parking brake. Steering ratio 4.1:1 gear reduction. Turning radius 31-1/2" inside rear tire. Tires Pneumatic. High-flotation 23 x 8.50-12 rear; 4.80/4.00 X 8 front. Dimensions
(without attachments)
39" wide, 72" long,
37-3/4" high.
48" wheelbase.
Rotary Mower Size 42" Height adjustable, 1-5/8" to 3-1/8" Seat Vinyl covered foam rubber, bucket
  • redcarkids said thank you
#12 Michiganmobileman OFFLINE
Posted February 23, 2012 - 10:31 PM
Thats a nice find!! Even better when you know the history of the machine you are about to buy. :thumbs:
#13 inkman232001 OFFLINE
inkman232001
  • 16 Thanks
  • 59 posts
Posted June 02, 2012 - 05:35 PM
if anyone is interested in this tractor i am selling it. all i got to do to it was put a carb on it and that is as far as i got. trying to get what i paid for it. Not going to have the time or money this summer to do anything else to it and i hate to see it just sit there..
