What Year?
21 replies to this topic
#1 cedarjunki OFFLINE
cedarjunki
  • 3 Thanks
  • 27 posts
Posted February 22, 2012 - 05:24 AM
are there any links, or places to help cross the serial numbers to find out what year we have? i have done a bit of searching the past couple days and cant seem to come up with very much. other than the engine code? i havnt tinkered with it at all yet but the serial number off the mower deck is 59732 1937....anyone know the year?? all i know is that its a ford 100..........and looks very old! is it worth keeping for the use of the snow thrower and using to pull trailers??
Edited by cedarjunki, February 22, 2012 - 05:24 AM.
#2 KennyP ONLINE
  • 38,453 Thanks
  • 45,965 posts
Posted February 22, 2012 - 05:28 AM
None that I know of. I used the engine #'s to guess on my year. Since my engine was made near the end of '76 and the closed side models came out in '77, I figured mine to be an early '77 model.
#3 mjodrey OFFLINE
  • 2,356 Thanks
Posted February 22, 2012 - 05:39 AM
Looks early 70s to me.
#4 cedarjunki OFFLINE
cedarjunki
  • 3 Thanks
  • 27 posts
Posted February 22, 2012 - 05:46 AM
i guess ill have to open her up and check the engine serial #...i was thinking it would be early to mid sixties myself..hard to go by the engine though, not knowing if its original or not.
#5 mjodrey OFFLINE
  • 2,356 Thanks
Posted February 22, 2012 - 05:58 AM
Not early to mid 60s,but I would say late 60s to early 70s.
My guess from that photo,which doesn't show it the best,would be right around 1970,give or take a year or two.
Edited by mjodrey, February 22, 2012 - 06:00 AM.
#6 cedarjunki OFFLINE
cedarjunki
  • 3 Thanks
  • 27 posts
Posted February 22, 2012 - 06:05 AM
but if i put up a better pic then you can see just how bad it is :/ jk it is rough! it also has the manual pto clutch, and is not a hydro! the main reason i took it!
#7 josh deaven OFFLINE
josh deaven
  • 479 Thanks
  • 574 posts
Posted February 22, 2012 - 09:40 AM
There should be a tag on the side of the grill.To get the serial#
#8 cedarjunki OFFLINE
cedarjunki
  • 3 Thanks
  • 27 posts
Posted February 22, 2012 - 01:01 PM
according to this post.... http://gardentractor...post__p__137692
its a 1967. or atleast the engine is, k241-c246084 spec #46519d should be a 10 horse correct?
#9 daytime dave OFFLINE
  • 4,845 Thanks
  • 6,545 posts
Posted February 22, 2012 - 05:00 PM
Looks like you have it right. Should be a 10 hp. Nice looking ford and blower.
#10 cedarjunki OFFLINE
cedarjunki
  • 3 Thanks
  • 27 posts
Posted February 22, 2012 - 05:44 PM
thanks daytime, its missing some parts though. i need to figure out how the lift rod actually runs and fabricate something.
as well as fabricate the blower engagement lever/rod. ive been searching for pics of both areas but not having much luck. the manuals here are for newer or different models than this one.
although i did fire it up today for a short time, sounds great but i have alot of work to redo from the previous owner.
and need to throw some good front tires on it.
just hope i didnt waste any money getting this thing.
Edited by cedarjunki, February 22, 2012 - 05:44 PM.
#11 josh deaven OFFLINE
josh deaven
  • 479 Thanks
  • 574 posts
Posted February 22, 2012 - 07:36 PM
Does your tractor have a tag on the left side of the grill?If it does then we can the year of tractor.It is probly a 67,but would like to help know for sure.later Josh
#12 cedarjunki OFFLINE
cedarjunki
  • 3 Thanks
  • 27 posts
Posted February 22, 2012 - 07:54 PM
i didnt notice one today Josh, but i will check tomorrow.
is there a specific reason these tractors have 5 lug rims but only 3 lug hubs?
#13 lsaltis1961 OFFLINE
lsaltis1961
  • 13 Thanks
  • 26 posts
Posted February 22, 2012 - 08:09 PM
Nice machine....better than my 66 (based on the engine serial number) when I got it. Slowly restoring it. I'll try to upload a manual for a similar year Jacobsen snow blower. .
#14 josh deaven OFFLINE
josh deaven
  • 479 Thanks
  • 574 posts
Posted February 22, 2012 - 08:20 PM
That is just an early style hub that is all.
#15 cedarjunki OFFLINE
cedarjunki
  • 3 Thanks
  • 27 posts
Posted February 23, 2012 - 05:17 AM
did you cut the hole in the hood for access to the fuel tank? or did some come like that? i was not pleased about having to unbolt mine to put gas in just to try and start it, let alone imagining having to every time to fill it up....im guessing originally there must have been some type of knobs or something other than nuts n bolts?
