D4-10 Is Back!
24 replies to this topic
#1 mixedbreed96 OFFLINE
mixedbreed96
  • 11 Thanks
  • 167 posts
Posted February 21, 2012 - 05:03 PM
Well went and picked my old bush hog back up from georges yesterday, now its time to get to work. Im in need of a new carb, or carb rebuild kit for a Zenith 68-7 carb, a starter generator, air filter assembly, 1 original front rim, and a battery. The battery I can obviously pick up from walmart, but the rest im going to need some help on. I also need a joint for the driveshaft to hook the driveshaft to the motors shaft. Any help is greatly appreciated! Thanks, Ryan.
  • 14,730 Thanks
  • 15,470 posts
Posted February 21, 2012 - 05:11 PM
olcowhand might be able to help you out.
#3 Bolens 1000 OFFLINE
  • 14,902 Thanks
  • 18,100 posts
Posted February 21, 2012 - 05:18 PM
If its the TRA-10D wisconsin you need parts for you can check with our site sponsor bhts : He has kits available on his website
http://store.bobsgar...?product_id=109
I have been getting air filters on ebay for the TR/TRA-10D
Just type in wisconsin LO173B and you will see some for around 14.75
  • mixedbreed96 said thank you
#4 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted February 21, 2012 - 05:23 PM
Ryan, remember, I have the air filter assembly, and golf cart front wheels. Did you ask George about his BH's original front rims, or did you forget? lol
Can't wait to see it done up. If you want to keep it for yourself than go ahead and buy the air filter assembly. I know Bob has everything you need to rebuild the engine and Daniel can help with the coupler.
#5 olcowhand OFFLINE
  • 40,350 Thanks
  • 31,170 posts
Posted February 21, 2012 - 05:27 PM
The joint isn't a universal like you'd expect. More of a slotted coupler. I'll see if I can get a pic of one tomorrow. I could likely make one if I have a correct size piece of steel to machine it from. I don't have an original rim available. My parts tractor had boat trailer rims on it's front, and I used the driveshaft coupler from it already.
#6 mixedbreed96 OFFLINE
mixedbreed96
  • 11 Thanks
  • 167 posts
Posted February 21, 2012 - 05:31 PM
haha george wasnt home when i picked it up. and i really want to buy the hog and 210 off of you
#7 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted February 21, 2012 - 05:36 PM
You need to ask George about the front rims off his BH that he added tri ribs to. He may part with the original rims to you, he had offered them to me if I wanted them. (I was planning what he had done so I passed on them.)
And if you want to buy that BH back in addition to the 210, I have zero problem with that.
#8 mixedbreed96 OFFLINE
mixedbreed96
  • 11 Thanks
  • 167 posts
Posted February 21, 2012 - 05:44 PM
tyhat sounds great. i just was out looking at the driveshaft area, man that thing is dirty haha. does bob have starter generator stuff?
#9 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted February 21, 2012 - 05:47 PM
Some, depends on what he gets in mainly. He mostly gets the newer than S/G engines, but I am sure he has one of two around that are good. Just be sure to get one big enough.
#10 olcowhand OFFLINE
  • 40,350 Thanks
  • 31,170 posts
Posted February 21, 2012 - 06:44 PM
Well went and picked my old bush hog back up from georges yesterday, Ryan.
So you & Casey both had a Bush Hog at George's place?
#11 mixedbreed96 OFFLINE
mixedbreed96
  • 11 Thanks
  • 167 posts
Posted February 21, 2012 - 06:55 PM
how much for the air filter assembly that you have?
#12 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted February 21, 2012 - 07:03 PM
It is on another Wisconsin of mine, will look it over tomorrow. No filter though..
#13 mixedbreed96 OFFLINE
mixedbreed96
  • 11 Thanks
  • 167 posts
Posted February 21, 2012 - 07:08 PM
Olcowhand, i sold the d4-10 to casey and he was picking it up at georges, now im buying it back so i went and picked it up haha.;
#14 olcowhand OFFLINE
  • 40,350 Thanks
  • 31,170 posts
Posted February 21, 2012 - 07:10 PM
Casey can't handle a Bush Hog huh! :smilewink:
#15 olcowhand OFFLINE
  • 40,350 Thanks
  • 31,170 posts
Then Casey gets booted from the Bush Hog club!
