* * * * * 1 votes
Trailer
46 replies to this topic
#1 maddhorse OFFLINE
maddhorse
  • 52 Thanks
  • 85 posts
Posted February 20, 2012 - 10:40 PM
Trailers! I had my alluminum stolen awhile back and am building a new steel one. I read otherposts saying 6 x 10 or 6.5 x 12. I got this frame for free it was a pop up camper. It had been completly torn down, even the wires pulled. I cut 11inches off each side as I did not want the sides out past the tires unless the tires were underneath. Put new brake kit in and wheel bearings then started welding. I am working up a place for a winch on the front and ramps 8' long to keep a shallow angle. I would get fustrated with snowblowers and tillers getting hung up on ramp so you need to take them off to load / unload tractor. It will be 5 x 12.4 I will be decking with 1 x 6 rough cut hemlock. It should be better than my last trailer, if nothing else brakes and sway hitch are nice when hauling 2,000 pounds on Maines back roads. I am curious to hear what you guys think and will post more pics as I go.
#2 jdslednut OFFLINE
jdslednut
  • 679 Thanks
  • 851 posts
Posted February 20, 2012 - 10:55 PM
I'm in trailer planning mode myself and have thought about a pop-up camper frame. Your progress is confirming my thoughts. Looks to be a lot more cost-effective than starting from scratch. Do you feel the original frame is heavy enough? Does it twist like those Tractor Supply ones if you sit on the front corner?
#3 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted February 20, 2012 - 10:56 PM
It looks to be a good build and a good base to build on. I too have a 5X8 on a pop up camper frame. From my perspective 5 ft is barely wide enough.
Mine has the wheels inside the 5 ft and I can't load my JD 318 with 48" mower on it?
Edited by JD DANNELS, February 20, 2012 - 10:57 PM.
#4 tinner OFFLINE
tinner
  • 503 Thanks
  • 1,561 posts
Posted February 20, 2012 - 11:46 PM
Good start on the trailer, should be a nice one when you're finished.
#5 mjodrey OFFLINE
  • 2,356 Thanks
Posted February 21, 2012 - 05:43 AM
:ditto:
#6 KennyP OFFLINE
  • 38,408 Thanks
  • 45,945 posts
Posted February 21, 2012 - 05:48 AM
Looks good, but some mowing deck get quite wide. The 48" deck for my Cub 108 is just over 5' wide. Good luck with you build.
#7 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted February 21, 2012 - 06:34 AM
:good_job:
#8 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted February 21, 2012 - 06:46 AM
Looking good!
#9 daytime dave ONLINE
  • 4,845 Thanks
  • 6,545 posts
Posted February 21, 2012 - 08:44 AM
Looks good. Looking forward to following your progress.
Edited by daytime dave, February 21, 2012 - 08:45 AM.
#10 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted February 21, 2012 - 08:47 AM
looks good and brakes will be great on it.
#11 Ryan313 ONLINE
  • 3,367 Thanks
  • 5,231 posts
Posted February 21, 2012 - 01:31 PM
Looks great, this is one I will be following.
#12 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted February 21, 2012 - 05:41 PM
Great progress on that trailer, looks to be a great re purposing. Glad you cut the width, never did care for the ugly of the tire IN the bed.
#13 maddhorse OFFLINE
maddhorse
  • 52 Thanks
  • 85 posts
Posted February 21, 2012 - 07:20 PM
I brought home some rough cut hemlock and painted edges and under side with used engine oil. I also wrapped up the welding. I will post pics tomorrow it was dark when I was done. Tractorholic, The frame is a lot better than those mass fabricated bought at a store trailers. Once the deck is on it will be very solid. I almost purchased one from Tractor Supply I would have been happy except I would have settled for smaller more affordable one. I got this frame for free and thought that the extras I could build into it would make me happier. I’ll have about $500 in it when I am done. I used a lot of bed rails and scraps to cut on costs. I also thought about mowing decks and the width. I figure I don’t mind wrestling with a mower deck but I do mind fighting a snow blower or tiller. Every time I lift either I drag it up my shin. Those damn things are heavy and solid; I don’t want to try lifting one into the back of my truck again. I promise Pics tomorrow morning.
#14 Cvans ONLINE
  • 6,649 Thanks
  • 6,130 posts
Posted February 21, 2012 - 08:03 PM
Creative thinking on the Pop up trailer frame. Should make you a nice set up.
Good luck with your project.
#15 caseguy OFFLINE
  • 1,628 Thanks
Posted February 21, 2012 - 09:01 PM
Looks like a solid and useful project! There's a lot of things you're adding that will make it a great tool for you to use! I would love to build my own trailer, but in PA the DOT makes it nigh on impossible to do it legally! Great fabrication work!
