Bolens Ht20 Diesel Repower
97 replies to this topic
#91 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted April 21, 2013 - 08:53 AM
you guys and your diesel repowers... wish I had an old cub to do that to. I would use a gear drive though.They seem more stout to me. Then again the only hydro I ever had was an old cub 129...
Hey Aint nothin to it but to do it! Get after it!
#92 8tyman8 OFFLINE
8tyman8
  • 416 Thanks
  • 731 posts
Posted April 21, 2013 - 11:03 AM
Haha Yeah i didnt like it either. Still need to find a rubber hose to connect the intake to the air cleaner but what i have will do for now.  I dont know how many times ive done something and hated the way it was. The 1250 will have the clear precleaner bowl through the hood if i ever get around to finishing it.
Mine is made with a pin and a bolt that has a wing nut so you can remove the air cleaner assembly quickly if you need to work on something
#93 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted April 21, 2013 - 01:41 PM
Modified hydro linkage. Had to  make a new bushing for the pedal shaft and added a grease fitting.
Works pretty well and hopefully it will provide years of service.
  • olcowhand said thank you
#94 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted June 09, 2013 - 08:43 AM
Well last weekend i got the tractor 90% wired. Just need finish the headlights, tail light and hour meter i added.  installed a temp gauge and a voltmeter. The low oil  pressure light and hydro temp warning light are hooked up.  I picked up a deck for it and  mowed the grass a few times already.   Ill run it a while longer and if i dont have any issues ill tear it down for body work and paint.  Unfortunately ill be gone for at least 3 weeks for work so its going to have to wait.
  • olcowhand, 8tyman8 and Utah Smitty have said thanks
#95 Utah Smitty OFFLINE
Utah Smitty
  • 1,713 Thanks
  • 1,793 posts
Posted June 16, 2013 - 10:48 AM
Can the oil pan on that engine just be unbolted and replaced with the standard metal pan? Something I've wondered about. I was offered several of these units out of small portable AC units. I'm not sure of the brand but He's very interested knowing if I could find a use for them as they are just in his way. The oil pan was my only concern.
Daniel I believe the engine in your G4200 is a Z430. I have two of those tractors. 12 hp.
I had one out of a reefer with the oversized pan... You can buy other pans for it.  In a moment of weakness (and to help clear out my garage) I sold it.  Now I wish I had it back.
Any info on those you were offered??--price, location, etc.  I'd be interested in one.
Smitty
#96 Utah Smitty OFFLINE
Utah Smitty
  • 1,713 Thanks
  • 1,793 posts
Posted June 16, 2013 - 11:03 AM
I'm Jealous!!!  Great Job... that thing moves like a hot knife through butter.
Smitty
#97 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted July 07, 2013 - 04:32 PM
Smitty
quite a few changes since then
#98 olcowhand ONLINE
  • 43,139 Thanks
  • 32,005 posts
Posted July 07, 2013 - 04:41 PM
Well.......let see them!   :wewantpics:
