Bolens Ht20 Diesel Repower
97 replies to this topic
#16 olcowhand OFFLINE
  • 41,150 Thanks
  • 31,416 posts
Posted February 19, 2012 - 10:16 PM
Daniel I believe the engine in your G4200 is a Z430. I have two of those tractors. 12 hp.
Well dang if I hadn't been wrong all this time! I thought I saw somewhere it was a 482, but never really needed to know, as she runs so good & only needed oil changes at this point! Thanks Chris, but now I feel kinda stupid, being it's my own tractor & all!
Kubota Tractor Model Kubota Engine Model
G4200 Z430
Engine Model: Z430 Head Bolt Torque: 32
Tractor Model: G4200 Main Bearing Case Bolt 1 Torque: 11
# of Cylinders: 2 Main Bearing Case Bolt 2 Torque: 17
Displacement (CC): 430 Rod Bolt Torque: 14
Displacement (Cu In): 26.2 Flywheel Bolt Torque: 44
Bore (MM): 66 Rocker Arm Bolt Torque: 8
Bore (In): 2.59 Compression (PSI) Standard: 450
Stroke (MM): 62.2 Compression Lower Limit: 325
Stroke (In): 24.5
Engine HP (Net): 12
Valve Clearance (Cold): 0.007
Piston Ring End Gap (RV): 0.017
Piston Ring End Gap (AL): 0.035
Main Crank Journal (Front): 1.5722
Main Crank Journal (Center): 1.5722
Main Crank Journal (Rear): 1.5722
Rod Journals (Standard): 1.3369
Crankshaft End Play: 0.012
Front Pulley Nut Torque: 80
Cylinder Liner ID (RV): 2.5984
Cylinder Liner ID (AL): 2.6043
Piston Diameter: 2.674
Dimensions are inches. Torques are foot pounds.
#17 chad zehr OFFLINE
chad zehr
  • 22 Thanks
  • 24 posts
Posted February 19, 2012 - 10:18 PM
Wish I had one of those for my massey ferguson mf14 repower!
#18 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted February 19, 2012 - 11:42 PM
Im deffinetly going to be watching this one closely. I can't wait to see it finished!
#19 Cvans OFFLINE
  • 6,648 Thanks
  • 6,129 posts
Posted February 19, 2012 - 11:58 PM
No big deal. Most wouldn't know but I'd hate to see you order parts and have them come for the wrong engine. Either way they are a great little engine. I sure like mine.
#20 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted February 20, 2012 - 12:56 AM
Great looking project, can't wait to see it running around at PA Plow Day this year. Do you give free driving lessons... like onto my truck. :bigrofl:
#21 mjodrey OFFLINE
  • 2,355 Thanks
Posted February 20, 2012 - 05:22 AM
It looks good sitting in there.
#22 skyrydr2 OFFLINE
  • 3,893 Thanks
  • 3,411 posts
Posted February 20, 2012 - 09:01 AM
Way to Frank! I'm watching too.
#23 Boss 448 OFFLINE
Boss 448
  • 48 Thanks
  • 248 posts
Posted February 22, 2012 - 08:46 AM
I would consider that agreeable as long as your GPS is set to my place!
#24 grand OFFLINE
grand
  • 2,043 Thanks
  • 2,015 posts
Posted February 29, 2012 - 09:44 PM
Thanks for the pics Frank. Hope to see it running at Plow Day.
#25 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted March 03, 2012 - 05:25 PM
Today i swapped the oil pan, crank pulley and added a cooling fan to the water pump. I then cut the cross shaft for the hydro pedal and mounted a bushing on the end of it so i had room for the driveshaft. I then made the engine mounts and attached the engine to the frame. I then made a new 2 piece driveshaft.
I plan on mounting the radiator up front on this one. Probably get a smaller fuel tank and relocate the battery so it has good airflow. Tomorrow i might Do the exhaust, mount the fuel filter and start some wiring.
  • olcowhand said thank you
#26 olcowhand OFFLINE
  • 41,150 Thanks
  • 31,416 posts
Posted March 03, 2012 - 05:28 PM
Looking real good so far Frank! Sure sucks that we don't have more time for our projects, but lately you've been making major headway.
#27 caseguy OFFLINE
  • 1,628 Thanks
Posted March 03, 2012 - 07:26 PM
That's looking really good! You've got some nice engineering going on there too!
#28 mjodrey OFFLINE
  • 2,355 Thanks
Posted March 04, 2012 - 06:44 AM
Frank,that is looking really great.You're making good headway.Thanks for the update.
#29 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 04, 2012 - 07:44 AM
Coming right along great, your making very good progress.
#30 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted March 04, 2012 - 03:40 PM
Looking great. So are you on track to finish by plow day?
