Can Anybody Id This Plow
15 replies to this topic
#1 Littledeere OFFLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted February 18, 2012 - 07:02 PM
Came across this plow does not look like a horse plow looks more like a GT
but maybe from a 2 wheel tractor any ideas guys
  • 14,800 Thanks
  • 15,495 posts
Posted February 18, 2012 - 07:07 PM
I have no idea, but wonder if it's part of a gang plow that had guys walking around on a platform letting each bottom down.
Pulled by a big steam engine.
  • Littledeere said thank you
#3 MH81 OFFLINE
Posted February 18, 2012 - 07:17 PM
I thought that too, either that or from a Riding plow pulled by a horse.
Can't quite read what's on it, can you make it out in person?
#4 Reverend Blair OFFLINE
Reverend Blair
  • 501 Thanks
  • 952 posts
I think Brian is onto something...it looks like a component of something larger.
#5 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted February 18, 2012 - 07:21 PM
Did not dawn on me till you mentioned it Brian but that would be my guess as well. Next time I see one of those I will take a lot closer look.
#6 caseguy OFFLINE
  • 1,628 Thanks
Posted February 18, 2012 - 07:33 PM
From the pic, it appears to say "Grange A08". The line under and to the right of that starts "Loun..." There might be more, but that's where the pic stops. I would agree that it is part of a larger whole, or is at least incomplete as shown, as I do not see a viable hitching point. Were you able to determine the size of the plow?
#7 Littledeere OFFLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted February 18, 2012 - 07:35 PM
That maybe guys but the beam looks kind of small for that
but then again I have not seen any plow made like this
Here are some more pics
#8 Littledeere OFFLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted February 18, 2012 - 07:42 PM
Looks to be a 10 inch plow but I have not put a rule on it yet
and this is lighter than a Brinly sleeve plow
#9 Littledeere OFFLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted February 18, 2012 - 07:54 PM
There are 2 bolts here
#10 olcowhand OFFLINE
  • 41,092 Thanks
  • 31,402 posts
Posted February 18, 2012 - 08:05 PM
Blount Plow Works had a business in Evansville IN till about the the 40s. It looks like it might possibly bolt to a sleeve hitch???
#11 OldBuzzard ONLINE
OldBuzzard
  • 7,021 Thanks
  • 4,792 posts
Posted February 18, 2012 - 08:17 PM
I did some Googling, and found:
That it was made by the Blount Plow Works. Blount started in Evansville, IN in 1867, and changed their name to BURCH in 1927.
Now, given the above, I would hazard a guess that your's was made in 1927 or earlier. So, it wouldn't have been for a GT.
I can't find anything specific about the A08 model.
#12 Gtractor OFFLINE
Gtractor
    G-agressive tractor
  • 9,314 Thanks
  • 4,949 posts
Posted February 18, 2012 - 10:04 PM
It is for a Standard Twin.
The two bolts highlighted in post #9 drop down through the implement mount [drawbar] on the tractor making the bolts verticle and moving the adjustment handle back toward the operator. If I remember right the rectangular bracket that is loose is upside down in the pic but it bolts to the cradle and the reason it is so wide is for side to side travel for steering.
Edited by Gtractor, February 18, 2012 - 10:13 PM.
  • caseguy and Littledeere have said thanks
#13 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted February 18, 2012 - 10:10 PM
yes its for a standard twin. had one just like it until last yr.
#14 MH81 OFFLINE
Posted February 18, 2012 - 10:13 PM
Looks like the one under this sulky.
#15 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted February 18, 2012 - 10:16 PM
Thought id deleted these but here a newer model one and if you look closely one on a 35 twin, its the same one as in the pictures with the same printing on the castings.
