Elec Trac E20 Refurbishing
97 replies to this topic
#91 MH81 OFFLINE
Posted December 15, 2012 - 01:53 AM
Good news on the charger Casey, and the battery box is looking great too.
  • wvbuzzmaster said thank you
#92 KennyP ONLINE
  • 38,302 Thanks
  • 45,899 posts
Posted December 15, 2012 - 05:29 AM
You're moving along at a good pace, Casey. keep it up!
#93 mjodrey OFFLINE
Posted December 15, 2012 - 06:14 AM
Casey,you're coming right a long.Looking good.
Edited by mjodrey, December 15, 2012 - 06:15 AM.
#94 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted December 15, 2012 - 08:19 AM
Casey will you need to clean the sandblaster parts with any special cleaners or different prep to get the areas the the 80 grit sandpaper won't get ? Like the deep pits .Al
#95 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted December 15, 2012 - 11:05 AM
Al, I am unsure of any special proceedures after sandblasting. All the 80 grit was for was to smooth up the surfaces of the texture the sandblasting gave. I actually used the 40 grit on the inside of the box case I was after crud. I blow the parts off with air before painting always. The deep pits were sanded with the sandblaster, so I figured they are rust free now, so that is fine. I do not plan to use body putty on this project, just paint, as this is not a true restoration, just a refurbishing. Any pitting or dents add character. My overall goal is for it to look great, but not so great I am afraid to put it to work lol.
I dont think any special cleaners are necessary before painting after sandblasting. I just know if you don't get paint on it soon it will flash rust like any other piece of untreated steel.
#96 daytime dave OFFLINE
  • 4,835 Thanks
  • 6,541 posts
Posted December 15, 2012 - 11:30 AM
Congrats on getting that charger Casey. Looks like good progress.
#97 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted December 15, 2012 - 01:49 PM
The weather today was not looking like it was going to get over 50 degrees (and I was right) and that was the weather wanted for painting outside. I opted to not work on the Elec Trak today anyhow, and went to work on a more pressing project, the topper needed the notches around the tailgate enlarged. So I ended up with about an hour or so in that project, and blew up two dremel cutting disks in my face (glad I had on the big goofy safety glasses today which were the first pair I found). Anyway, I will get back to the Elec-Trak tomorrow. It is perfectly ok to not make progress on the same project, as long as I did do something constructive today lol.
#98 Sparky OFFLINE
Sparky
  • 1,298 Thanks
  • 1,892 posts
Posted December 15, 2012 - 02:18 PM
Casey - I have a foot pedal that is stock with a pad and the little prongs . As I recall that one has a welded hinge . N/C to you.
