46 Bean Cutler-1
22 replies to this topic
#1 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 4,197 Thanks
  • 1,917 posts
Posted February 18, 2012 - 12:59 PM
The transmission and engine mounting frame are ready to set back down on the floor.
This is a heavy unit but I felt that this was still light enough that it could be moved with my lift cart.
The transmission is tilted back onto the lift table and supported by wood blocks.
then I rolled the stand out of the way and set the transmission down so it is resting one some support blocks.
Most of this week has been spent sanding down a lot of the parts and getting them painted.
#2 caseguy OFFLINE
  • 1,629 Thanks
Posted February 18, 2012 - 02:42 PM
Looking great as always Ray! I wish I had your motivation!
  • jdcrawler said thank you
#3 KennyP ONLINE
  • 40,881 Thanks
  • 47,094 posts
Posted February 18, 2012 - 02:52 PM
That's gonna be a nice looking machine. Great job, Ray!
#4 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted February 18, 2012 - 02:55 PM
Ray, that looks great. I hope my Elek Trak repaint turns out just as good as yours.
#5 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted February 18, 2012 - 02:56 PM
Looks great! That thing looks pretty heavy, it could definitely do some damage if it fell. Its going to look amazing put together!
#6 grand OFFLINE
grand
  • 2,210 Thanks
  • 2,054 posts
Posted February 18, 2012 - 06:24 PM
It's almost like looking at pics of new parts Ray. You are doing a great job as usual. Thanks for sharing and I look forward to more updates.
#7 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 4,197 Thanks
  • 1,917 posts
Posted February 21, 2012 - 12:56 PM
Time to start putting this back together.
The main frame is set down onto the pivot shaft on the top of the transmission.
then I supported the rear of the frame with the lift cart and assembled the rear axle arms and wheel hubs.
The rear wheels were bolted on and the tractor was set down on the rear tires.
the front of the tractor was jacked up and the front wheels were bolted on.
Here's a view from the rear.
Because this is going to be set up as a mower and not a garden tractor, I'm using a lawn type tire tread instead of the normal tractor lug style.
The front tires have about 3/8 inch clearance between the tire and the back of the front plate.
It's time to get out the reel mower units and start soaking them down with a degreaser.
They have some real heavy grease on them so I want to be able to let them soak for a few days before I wash them off.
#8 wilberj OFFLINE
wilberj
  • 5,096 Thanks
  • 5,625 posts
Posted February 21, 2012 - 01:09 PM
Ray this is the restore I been hopeing to see for a long time and your off to a great start.
I cant wait to see how the mowers get put on it.
#9 Bolens 1000 OFFLINE
  • 15,416 Thanks
  • 18,279 posts
Posted February 21, 2012 - 01:13 PM
Awesome job so far Ray!!!
Like wilberj posted above, I cant wait to see those reels on it.
Are those actual Bolens reels that were meant to fit the Ridemaster?
#10 mjodrey OFFLINE
Posted February 21, 2012 - 01:25 PM
Looking great ,Ray. :thumbs:
#11 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted February 21, 2012 - 01:35 PM
Looks good so far. Those reel mowers will be a nice addition!
#12 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 4,197 Thanks
  • 1,917 posts
Posted February 21, 2012 - 02:48 PM
The reel mowers are not Bolens units.
They are a 3-gand setup that was designed to be pulled behind a tractor.
The Ridemasters had a reel mower setup that actually fit up under the tractor but the Bean cutler never had a mower setup.
After all this time, I still haven't decided if I want to make these so they are pulled behind or actually mount them up under the tractor.
Here's a photo of a Ridemaster with the reel mowers on it.
  • Bolens 1000 and KennyP have said thanks
#13 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted February 21, 2012 - 05:32 PM
Great progress there Ray, nothing like rolling chassis status.
You should mount them underneath, you need a good challenge trying to get them all to lift, lower, and float together and separately lol.
Edited by wvbuzzmaster, February 21, 2012 - 05:33 PM.
#14 caseguy OFFLINE
  • 1,629 Thanks
Posted February 21, 2012 - 05:55 PM
This will be a fantastic build thread Ray! I really like the looks of it so far! Is that the original color?
#15 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted February 21, 2012 - 05:58 PM
Coming along nicely, that's going to be a sweet mower,
