Jd 210 Clutch Adj?
2 replies to this topic
#1 Rdcd111 OFFLINE
Rdcd111
  • 1 Thanks
  • 4 posts
Posted February 18, 2012 - 12:08 PM
Hello men. I just put new (JD) drive belts on my JD 210 and what a difference! It will snap your neck when it grabs, compaired to the junk aftermarket ones that slipped more and more over a short time.
I noticed the Clutch is very hard to push in the last 2" or so when it is engaging. Is there an Adj for this? I also Adj the brake band and now they work. I wonder if that has somthing to do with the hard Clutch?
But it works great now, just a hard clutch pedal for last 2" when it counts. And when it grabs it grabs! Will the new belts break in a bit and loosen up the clutch pedel in time? Thanks in advance for the help. Ray
#2 JDBrian OFFLINE
  • 9,642 Thanks
  • 14,157 posts
Posted February 18, 2012 - 02:41 PM
Do you have the owners manual? There is some info on adjusting and maintenance in there that might help you. Send me a private message and with your email address and I'll send you a copy.
  • Rdcd111 said thank you
#3 lyall ONLINE
lyall
  • 2,171 Thanks
  • 1,573 posts
Posted February 20, 2012 - 09:49 PM
you will always have adjustments when putting on new belts. over the years the old belts wear and stretch and adjustment were made.
