Mep G15
military generator/2a016
38 replies to this topic
#16 mjodrey OFFLINE
Posted March 04, 2012 - 06:27 AM
Good looking stuff,thanks for the photos.
  • trowel said thank you
#17 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 07, 2012 - 06:01 PM
Today was a high of 50's and a day off so i started on the fuel tank bracket.
Here is the original tank, i cut the bottem out, it was riddled with pin holes and started wire brushing, was going to solder on a new bottem but the most of the metal is now rust.
I will save the gas level gauge and filler cap for another project.
#18 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 07, 2012 - 06:06 PM
This is what i started with, shown here is me bending the 1/4 inch x 2 inch flat bar on my 6 inch post vice, two holes for 7/16 th bolts were drilled on the bracket and the control box bracket on the genset.
Edited by trowel, March 07, 2012 - 06:07 PM.
#19 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 07, 2012 - 06:15 PM
Another shot of the bracket and the fuel tank sitting on it, now to trim the edges and weld on the ears for the fuel tank bolts.
#20 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 07, 2012 - 06:21 PM
Here's a shot of the bracket with the ears welded on and ground into shape, the tank is bolted on to make shure everything fits good.
Tomorow is going to be in the 60's and thursday in the mid 60's, i do not have a heated garage so cleaning and painting.
#21 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 08, 2012 - 08:23 AM
Now for the testing of the tank and bracket before cleaning and painting, more pictures will follow soon.
#22 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 08, 2012 - 04:53 PM
Dang ! no painting today, woke up to high winds and gusts so i replaced the coils.
#23 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 08, 2012 - 04:59 PM
Here's the what the insides of the control box looks like with the tool box removed, the tool box will be remounted in the other direction.
I mesured and marked off were the new holes will be thn drilled them out for 7/16 th bolts.
#24 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 08, 2012 - 05:04 PM
Here's the tool box remounted onto the control box, it opens to the control side so it can be used as a table for writing on, also shown is the the compartment that houses the Technical Manual im still currently looking for.
Edited by trowel, March 08, 2012 - 05:30 PM.
#25 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 08, 2012 - 05:20 PM
Here it is for the most part finished and running a vacuum cleaner, time to clean out all the sand from the cars.
Still a few more things to be tidied up and the bracket at least primed.
#26 mjodrey OFFLINE
Posted March 09, 2012 - 05:39 AM
That turned out pretty nice.
#27 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 09, 2012 - 04:49 PM
Weather was a little cooler then yesterday but at least the wind died down and the sun was warm so i cleaned up the bracket, bolts, pecock and shut off valve.
#28 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 09, 2012 - 04:52 PM
After washing and drying i primed everything.
#29 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 09, 2012 - 04:55 PM
Then painting, after 4 hours in the sun i bought the painted parts into the house to set up for a while.
While the paint was drying i fiddled with loose ends on the genset, may have to replace the valve covers.
Edited by trowel, March 09, 2012 - 04:59 PM.
#30 caseguy OFFLINE
  • 1,629 Thanks
Posted March 09, 2012 - 09:16 PM
That's really coming together Jesse! Very nice fabrication work on the mount! Sounds like it's pretty healthy too. Who made the engine?
