Trying To Identify This Tractor
5 replies to this topic
#1 ratnestss16 OFFLINE
ratnestss16
  • 6 Thanks
  • 19 posts
Posted February 15, 2012 - 01:32 PM
Just found an old Craftsman rider behind a shed were I deer hunt. It seems to be in good shape, only problem is it doesn't have a motor lol! So question is does anyone here have one like it and where can I fined parts or the original motor. The model number is 131.96461
#2 jimbobbillyray OFFLINE
jimbobbillyray
  • 3252 Thanks
  • 2967 posts
Posted February 15, 2012 - 02:15 PM
howdy. I used a google search engine and typed in the number 131.96461 and found a couple of things, it might be about an '84, 32" deck. it might have had a 7hp. tecumseh in it. Is is yellow with a gray frame? I only used 1 search engine. Ya might give that a shot using several different search engines. Good luck!
#3 ratnestss16 OFFLINE
ratnestss16
  • 6 Thanks
  • 19 posts
Posted February 15, 2012 - 05:06 PM
Ok thanks!
#4 glgrumpy OFFLINE
  • 9122 Thanks
  • 8205 posts
Posted February 15, 2012 - 07:16 PM
Most sears had Tecumseh Iron block engines. Can be troublesome and hard to find parts for, specially if the electronic ignition they had. You can put other engines in and be happy with it. Getting right shaft size is most important part. Sears are easy to work on and plenty of parts around. Hardest part is getting linkages and pedal control shafts out to rebuild or paint, an involved process! AND, the steering wheels never come off in one piece, ha!
#5 ratnestss16 OFFLINE
ratnestss16
  • 6 Thanks
  • 19 posts
Posted February 15, 2012 - 09:08 PM
If I just looked at the steering wheel on this mower wrong it would probably fall apart lol!
#6 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1189 Thanks
  • 1342 posts
Posted February 16, 2012 - 05:50 AM
According to the Sears parts site the engine part number is 752152 but is no longer available from them.
Edited by GTTinkerer, February 16, 2012 - 05:51 AM.
