* * * * * 1 votes
My 125
54 replies to this topic
#46 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted March 01, 2012 - 12:02 PM
When it was restored I painted it with some kind of texture black paint, I will see if I have any at my house and if I do I will see what it is. The original engine leaked oil like mad so my dad and I replaced it and the replacement was painted yellow. So, both. Lol
#47 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
#48 spinella OFFLINE
spinella
  • 6 Thanks
  • 57 posts
Posted March 01, 2012 - 12:40 PM
i just pulled the motor and i finally was able to take the steering tower off. what a pain that was. even though i can see the shaft for the hydro, i still cant free it up. it slides up and down when i press on the brake but it wont pivot from forward to reverse. i put heat on it and sprayed the crap out of it. i might have to try to dissemble it. i'll post pics tonight.
#49 spinella OFFLINE
spinella
  • 6 Thanks
  • 57 posts
Posted March 01, 2012 - 09:47 PM
heres some pics as promised. finally got the tower off and i freed up the hydro shifter. it was frozen right under the handle right above the big spring.
#50 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted March 01, 2012 - 10:03 PM
Did you remove the engine with the grill on?! I don't now how different the hydro version is but I didn't know that was possible! Its coming apart nicely! Good work!
#51 spinella OFFLINE
spinella
  • 6 Thanks
  • 57 posts
Posted March 01, 2012 - 10:17 PM
Yep. Grill stayed on. I just removed the voltage regulator. It's bolted to rear of the grill. I also removed the gen/alt. Lifted right out.
#52 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted March 01, 2012 - 10:22 PM
On gear drive cubs you have to slide it forward out of the clutch plate so the grill has to come off. Either way, the engine is off so it doesn't really matter anymore.
#53 IHCubGuy OFFLINE
IHCubGuy
  • 1,611 Thanks
  • 1,638 posts
Posted March 02, 2012 - 09:53 PM
just curiosity what color is your engine? mines black. i've seen them yellow and i've seen them black. i think mines original. good luck.
With the exception of the hoods and wheels all IH Cub Cadets are federal yellow (except for the 82 series). If it is black it is a replacement engine.
  • spinella said thank you
#54 spinella OFFLINE
spinella
  • 6 Thanks
  • 57 posts
Posted March 02, 2012 - 10:24 PM
Thanks. I searched the Internet and it seems there's almost the same amount of black as there is yellow. The tag on the engine is correct for the tractor. I like the look of the black engine. So I think I'm going to respray it black.
#55 mjodrey OFFLINE
Posted March 03, 2012 - 05:38 AM
You are making good progress on your Cub.
BTW,the engine on yours would have been yellow when it was new.
