* * * * * 1 votes
My 125
54 replies to this topic
#31 spinella OFFLINE
spinella
  • 6 Thanks
  • 57 posts
Posted February 16, 2012 - 08:20 AM
i think im going to fit right in with this group.... :laughingteeth:
#32 KennyP OFFLINE
  • 34,237 Thanks
  • 43,350 posts
Posted February 16, 2012 - 08:22 AM
thats just it, they were right side up when i view them on my computer. i'll try again with new photos from tonight. thanks.
Are these taken with a phone camera? Are you using that software to view? Maybe your kids can help show you how to get them to show up right.
#33 KennyP OFFLINE
  • 34,237 Thanks
  • 43,350 posts
Posted February 16, 2012 - 08:24 AM
We have a place for everyone. We like a well rounded forum.
  • Delmar said thank you
#34 tractorman604 OFFLINE
tractorman604
  • 269 Thanks
  • 694 posts
Posted February 16, 2012 - 08:32 AM
Welcome to the site spinella.The 125 looks good.
  • spinella said thank you
#35 spinella OFFLINE
spinella
  • 6 Thanks
  • 57 posts
Posted February 16, 2012 - 10:12 AM
yes they were taken with my IPHONE. when i opened them in a email or in FLIKR they look right. i'll take the next set of pics making sure i'm holding the phone right side up.
#36 spinella OFFLINE
spinella
  • 6 Thanks
  • 57 posts
Posted February 16, 2012 - 06:01 PM
Welcome to GT TALK. The guys here are some of the greatest on the net. The trick for getting a steering wheel off a cub is this. Carefully pry the center cap off the steering wheel and then take the nut off. It should be a thin nut so you need to get yourself a nut that is the regular thickness as well as a bolt about 2-3 inches long. The nut is a fine thread and I believe 3/4 inch. Thread the thick nut on the steering column halfway and then thread the bolt down into the nut and tighten it down against the steering column shaft. The next part may be harder without the fenders on. Sit yourself down on the seat with your feet on the footrest's and your knees under the steering wheel and push up on it from the bottom. Now get yourself a good sized short handle sledge and while pushing up with your knees on the bottom of the wheel give the bolt a couple good whacks. It should pop after a few good hits. I have used this method on all of my steering wheels and it has never failed me yet. The great advantage to it is its fairly easy and it causes no damage to the wheel or steering column and when done right should have the wheel off in ten minutes or less. Good luck.
i removed the steering wheel. it was a 5/8 ths fine thread nut. that trick worked like a charm.
the trans gear selector is'nt moving. i just sprayed it all down, i dont want to break the shifter....any tricks? half the problem is i havnt really wrapped my head around how this hydrostat trans works. i printed all the manuals that are available on this site. it took me a week to free up the brake pedal. it was parked with the brake lock on. also how do i become a supporter? anyone have a link? thanks.
Edited by spinella, February 16, 2012 - 06:04 PM.
#37 KennyP OFFLINE
  • 34,237 Thanks
  • 43,350 posts
Posted February 16, 2012 - 07:12 PM
Go here:
http://gardentractor...er-memberships/
It's in with the Store above.
#38 spinella OFFLINE
spinella
  • 6 Thanks
  • 57 posts
Posted February 16, 2012 - 09:25 PM
Go here:
thanks, i'll ask the wife to do it tommorrow.
#39 spinella OFFLINE
spinella
  • 6 Thanks
  • 57 posts
Posted February 20, 2012 - 03:59 PM
i just picked up the rims and fenders and seat frame along with side and rear covers from the sand blaster. i want to use an etching two part primer/epoxy. anyone know what paint and name of the colors i should use? (yellow and off white?) and manufacter of paint? any good results with a rattle can?
#40 mjodrey OFFLINE
Posted February 20, 2012 - 04:35 PM
That will make one nice Cub.
#41 Ryan313 OFFLINE
  • 3,242 Thanks
  • 5,159 posts
Posted February 20, 2012 - 05:37 PM
Mine was rattle canned, I think it came out pretty good. I believe it is caterpillar yellow and then krylon white. If done properly it comes out great.
#42 spinella OFFLINE
spinella
  • 6 Thanks
  • 57 posts
Posted February 21, 2012 - 07:04 AM
Thanks. I'll be wet sanding in between coats so I hope it comes out nice. Going to try and prime the parts tonight.
#43 4SPEED OFFLINE
4SPEED
  • 6 Thanks
  • 22 posts
Posted February 29, 2012 - 11:11 PM
nice ride..... I just got a 125 , I pic it up this weekend.. cant wait...
#44 spinella OFFLINE
spinella
  • 6 Thanks
  • 57 posts
Posted March 01, 2012 - 07:35 AM
sounds good...post pictures, everyone around here loves pictures. i wound up brush paint the sheetmetal cat yellow. i have two coats sanding in between and today i'll wet sand with 1000 grit and finish coat. i'm surprised at how nice its coming out. the rims i spray painted white. i had everything sand blasted, i think that makes a huge difference. i'm going to yank the motor today and prep the frame and rear for paint.
just curiosity what color is your engine? mines black. i've seen them yellow and i've seen them black. i think mines original. good luck.
#45 spinella OFFLINE
spinella
  • 6 Thanks
  • 57 posts
Posted March 01, 2012 - 07:38 AM
ryan what color is your engine painted? black or yellow?
