Building a homemade tractor
77 replies to this topic
#31 tractormike OFFLINE
tractormike
  • 172 Thanks
  • 1,488 posts
Posted June 22, 2010 - 07:37 AM
You are making good progress! Looks to be one heavy duty rig.
#32 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted June 22, 2010 - 04:39 PM
Thanks for all the comments! Today i slept in so I only got the gas tank mounts and battery tray installed.
#33 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted June 23, 2010 - 08:35 PM
Ok, thanks to Olcowhand it looks like the pump is about 17 gpm.
#34 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted June 23, 2010 - 08:56 PM
By the looks of the pump physical size, I'd say that is about right. You know that's a pretty good volume rate. One could put one pump on a flow divider & split it into 2 separate circuits with exactly 8 1/2gpm.
If you needed the full volume of one for the motion drive, then you'd still have 2 separate circuits for other duties.
Here is an adjustable one on ebay.
http://cgi.ebay.com/...=item5ad96da614
Edited by olcowhand, June 23, 2010 - 09:01 PM.
#35 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted June 24, 2010 - 02:51 PM
Sounds interesting... Could you explain how that would be a good idea? i'm still new to all this hydrualic stuff.
#36 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted June 24, 2010 - 03:55 PM
For one, 17gpm is a lot of flow for loader cylinders, so you could easily adjust how much flow to the loader control valves. PLUS, with the added split circuit, you could run a set of remotes independently, or have a separate valve for a clam jaw for your bucket.
#37 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted June 24, 2010 - 09:46 PM
Ah, now i see what you mean. I might try that remote thing, then I could have a power angle backblade, or the clam jaw on the bucket. I always liked seeing those on construction sites.
#38 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted June 30, 2010 - 01:36 PM
Alright, i got the hood from the Sears split and spread. Now to finding the steel to fill the gap. I also got the dash tower cut for the guage panel, and started the steering hubs. I'm using 5/8 solid rod through black steel pipe. Now i need to get some spindles with hubs. Probably no pics until the front tires are on and I can roll it out side.
#39 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 97 Thanks
  • 348 posts
Posted June 30, 2010 - 04:55 PM
I must say, This is an awesome build. I am one day gonna make the ultamite Garden tractor.
#40 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted June 30, 2010 - 09:43 PM
Thanks. Now i have a question. How should the 3pt lower arms be mounted? To the axle, or another bracket on the rear of the frame?
#41 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 97 Thanks
  • 348 posts
Posted July 01, 2010 - 11:06 AM
Depends, which is strongest? I hope your thinking of patenting this tractor. Its an awesome build with strength in mind. That is not around anymore my friend.
#42 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted July 01, 2010 - 09:30 PM
Don't we know it. The biggest reason for all the old stuff we have is because of that.
#43 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 97 Thanks
  • 348 posts
Posted July 02, 2010 - 11:40 PM
Ya, I had an Idea to build a strong GT sized tractor. But with all of it being hydraulically driven. even down to the deck being hydralic. So you just throw it under there and hit a lever and the hydro blades kick on. And it having a loader would possible to. But, the trans would be gear. Its still a wip thought but I am working on it.
#44 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted July 10, 2010 - 05:34 PM
Well i havent done much lately. The hood got a piece tacked into it, and looks horrible so it getting a new hood built once running. I'm getting a pair of FWD car hubs from a fellow member on the mytractorforum. Then i can start on the steering system.
PS does anyone know what hydrualic motor i should use?
#45 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted July 17, 2010 - 07:13 PM
Update: It has front wheels. I got the car hubs last week, and built some spindles. Then i mounted the tires. With front tires on it, i took the rears off, and pulled one of the drums. The wheel cylinders are junk, along with the pads and E-brake cables. $$$$ will burn to get brakes on this tractor.
