Building a homemade tractor
77 replies to this topic
#16 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted June 08, 2010 - 03:10 PM
Thanks, but progress will slow when the $$$ burns. Yesterday I found a steering column out of an old for truck with 3 on the tree. I have decided to use that for my steering, and use the shifters for controlling the direction the tractor moves, and the other will do something else???
#17 tractormike OFFLINE
tractormike
  • 172 Thanks
  • 1,488 posts
Posted June 09, 2010 - 08:00 AM
Quite a project you have going there :thumbs: I don't think you will be twisting those axle shafts off! Good luck on your tractor and keep us updated.
#18 chopperfreak2k1 OFFLINE
chopperfreak2k1
  • 18 Thanks
  • 431 posts
Posted June 09, 2010 - 04:53 PM
what an awesome undertaking! looks good so far, can't wait to watch it progress!
#19 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted June 09, 2010 - 08:40 PM
Yesterday I got the lower portion of the dash tower panels tacked in place. Today I got the steering column free, and cleaned inside. Thats all for now, probably more on Friday.
#20 massey driver ONLINE
massey driver
  • 1,483 Thanks
  • 1,592 posts
Posted June 11, 2010 - 07:31 PM
Looking good so far,thats a big undertaking,very interesting project for sure.Gonna keep my eye's on the build.I like seeing things come together. Larry
#21 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted June 13, 2010 - 07:51 PM
Does anyone know how to find out the pressure and flow for the pumps?
#22 olcowhand ONLINE
  • 42,496 Thanks
  • 31,833 posts
Posted June 13, 2010 - 08:08 PM
Make & model # of pump?
#23 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted June 14, 2010 - 09:04 PM
The name on them is webster, but i can't find a model number. Would the port size tell how big it is?
Just an update. I got the brace that the steering column, and found some pedal from some Massey garden tractors to use. Then I found the grille from the sears suburban 12 i saved, and fabbed up a mount for it so the top edge would sit above the air cleaner. I decided my front axle was too narrow, and that i wanted to us a set of rear turfs of an MF12 tractor that I saved as spares. So now the hunt is on for an axle to use. Im planning on a trip to the junkyard with my dad, so i hope to find some parts to use for this project.
Any suggestions on things to look for?
#24 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted June 19, 2010 - 10:20 PM
Update- Today i found a piece of steel to use for an axle. It is a pair of channel irons welded back to back. So i enlarged the holes, and welded in a sleeve to put the pivot bolt in, and added a pair of plates on the sides for strength. Earlier in the day I got the steering column tied in place with wire so i can bolt it in. Thats all for today since we were working on the go-kart we are building for my little brother. I'll get some pics tomorrow.
Does anyone have any ideas on finding the size of the pump?
#25 olcowhand ONLINE
  • 42,496 Thanks
  • 31,833 posts
Posted June 20, 2010 - 07:28 AM
They are sized according to volume, as in cc's or cubic inch. But I don't know if that's volume the pump holds, or volume it puts out with one revolution. I'll ask at a machine forum I belong to.
#26 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted June 21, 2010 - 06:43 PM
Thanks a bunch. Once i know what size the pump is I can start getting the valves. And now for the pics-
#27 chopperfreak2k1 OFFLINE
chopperfreak2k1
  • 18 Thanks
  • 431 posts
Posted June 21, 2010 - 07:40 PM
looks pretty impressive so far. good work!
#28 Bolens 1000 ONLINE
  • 15,298 Thanks
  • 18,236 posts
Posted June 21, 2010 - 08:59 PM
Its really comming together now.
Awesome job :thumbs:
#29 olcowhand ONLINE
  • 42,496 Thanks
  • 31,833 posts
Posted June 21, 2010 - 09:07 PM
All they could tell me was to prime each pump, then turn one revolution, & catch the oil that comes out. Will be easier using cc measurement. 10 cm³ = 0.610237 in³, so if it put out 10cc, you'd multiply that by 3,000 is that's the speed you'd run engine. That would give you 1830.7 cubic inches, which would be 7.92510 gal per minute.
#30 mjodrey OFFLINE
Posted June 22, 2010 - 04:25 AM
Boy you are making great progress so far,looking good.:thumbs:
