Outboard Motor Tilt/trim For A Gt?
hydraulics lift 3 point
17 replies to this topic
#16 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted February 11, 2012 - 01:56 PM
The old Mercruiser power trim units for inboard/outboard setups were separate from the cylinders, via small hydraulic lines, and would work great as an attachment lift system. The shock absorbers on the transom/engine were also the lift cylinders. I used to have one laying around, but no idea what happened with it.
There's 2 real easy ways to find it, 1) Don't hunt for it or 2) Go buy another one. Either way, lost things surface every time.!! :laughingteeth: :laughingteeth:
#17 IamSherwood OFFLINE
  • 8,395 Thanks
Posted February 12, 2012 - 07:08 AM
So far mostly Johnson---Same on CL 70s-to-80s, various HP, I think Johnson was the brand he mentioned. Unlike your unit with the internal plumbing, some of those were plumbed with rigid tube and appeared that you could separate.-Lee (which means the actuator could be mounted in any plane)
Probably the better way to go, considering mounting options, and if one component fails, it's less $ to replace.
  • Toolpartzman said thank you
#18 KennyP ONLINE
  • 40,103 Thanks
  • 46,756 posts
Posted February 12, 2012 - 07:31 AM
I'm glad you all brought this topic up, as I had forgotten all about these. Could be a fairly easy way to get a lift set-up.
Also tagged with one or more of these keywords: hydraulics, lift, 3 point
