46 Bean Cutler
11 replies to this topic
#1 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 4,197 Thanks
  • 1,917 posts
Posted February 10, 2012 - 11:37 AM
The last posting I did on this was over a year ago back in January 2011.
Here's what it looked like at that time.
I tried to pull the pulley off the drive shaft so the bearing could be changed but it was rusted on too tight and the gear puller wouldn't budge it.
So I removed the rear half of the transmission casing and took off the upper grive sprocket so the whole drive shaft could be slid out the front of the housing.
Then I put it in the press and pressed the drive shaft out of the pulley.
With the pulley removed, I could then unbolt the engine mounting frame and backing plate.
A new bearing was installed and the drive shaft was mounted back in the transmission housing.
The back of the transmission was then bolted back on and the assembly was rolled outside and degreased.
The transmission was then sanded down in preparation for painting.
This is how it looked as of early spring 2011.
So I spent the summer going to tractor shows and working on other projects while the Bean Cutler sat in the garage and gathered dust and this week I started working on it again.
The engine mounting frame and backing plate are sanded down and painted.
I also painted the brackets that lift the engine up and down.
The threaded lift adjustment bolt that fits in the engine mounting plate is in sad shape.
I took a piece of threaded rod and built up one end with brazing rod.
Then it was clamped in the mill vise so I could mill down the two sides.
One side is finished here.
After both sides are milled down flat, the brazed area is squared off to form the head of the bolt.
Here is the new lift bolt set next to the old lift bolt.
This is the slot that the lift bolt goes into.
The new bolt slips right in.
At this point I ran into a small problem.
The new front tires that I got for this tractor are a little bigger diameter than what the original tires were so they rub against the backing plate.
I want to stay with these tires so I made up two 3/8 inch thick spacers to go behind the backing plate.
Here are the spacers mounted in place between the transmission housing and the backing plate.
Here's how it looks so far.
Links to previous post.
A- http://gardentractor...mc-bean-cutler/
B- http://gardentractor...-bean-cutler-1/
Edited by jdcrawler, February 11, 2012 - 11:44 PM.
#2 Bolens 1000 ONLINE
  • 15,416 Thanks
  • 18,279 posts
Posted February 10, 2012 - 11:41 AM
Great Job so far Ray!!
Looking forward to watching this restoration unfold
  • jdcrawler said thank you
#3 KennyP OFFLINE
  • 40,881 Thanks
  • 47,091 posts
Posted February 10, 2012 - 12:05 PM
Looking good, Ray! Glad you got to get back to this, I missed the first parts.
#4 caseguy OFFLINE
  • 1,629 Thanks
Posted February 10, 2012 - 02:23 PM
I'm sure glad that you haven't run out of projects yet Ray! Always enjoy your threads!
#5 tinner OFFLINE
tinner
  • 503 Thanks
  • 1,561 posts
Posted February 10, 2012 - 09:26 PM
Looks like another great project. This must be the red one you were talking about. Looking good.
#6 wilberj OFFLINE
wilberj
  • 5,096 Thanks
  • 5,625 posts
Posted February 11, 2012 - 04:32 AM
Yes! the restore has started again!
#7 Lovintractorin OFFLINE
Lovintractorin
    Tinkerer
  • 159 Thanks
  • 603 posts
Posted February 11, 2012 - 08:25 PM
Looking good as always. :thumbs:
For some reason those links didn't work for me.
#8 Michiganmobileman OFFLINE
Posted February 11, 2012 - 08:42 PM
All right, here we go again :dancingbanana: Rays back to another project!
This will be a neat one to see come together as I am not sure what they are supposed to look like.
#9 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 4,197 Thanks
  • 1,917 posts
Posted February 11, 2012 - 11:07 PM
I tried the links myself and was not able to get them to work either.
After doing some resurch, I was able to re-set the links so they work now.
The FMC Bean cutler was the for runner to the Bolens Ridemaster.
This is what they look like.
Edited by jdcrawler, February 11, 2012 - 11:48 PM.
  • trowel and Michiganmobileman have said thanks
#10 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted February 12, 2012 - 12:26 AM
Awesome project Ray, keep up the great work.
#11 Michiganmobileman OFFLINE
Posted February 12, 2012 - 07:39 AM
Thanks for the picture Ray that does look similar to the RM, will still be neat to watch even now that I know what it will look like. :thumbs:
#12 grand OFFLINE
grand
  • 2,210 Thanks
  • 2,054 posts
Posted February 12, 2012 - 09:29 AM
Very nice work Ray. Thanks for the pics and the update.
