The Black stuff is Magnetite
21 replies to this topic
#16 WQDL753 OFFLINE
WQDL753
    Bolensholic
  • 59 Thanks
  • 301 posts
Posted February 08, 2012 - 07:40 PM
De-Ionized water will also work.....Although, I'm not sure how easy that is to find for normal people. lol
#17 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted February 09, 2012 - 07:43 AM
Kenny, can you share the label info on your Rustoleum product? My Loctite reads "Contains Acetone , Propane and Butane" "may cause rusting on non-rusted areas" and do not sand as it will break the bond". This is a hint that Acetone may be the "magic ingredient" as Propane/Butane are propellants. The reason I found that the black stuff won't rust is that it's stable ("not soluble in water") unlike bare steel. If Acetone does the same thing-(I'm going to get some now, because my can's empty):wallbanging: it may be cheaper than spray and easier to apply to inaccessable areas.??
I've got to find an anti-dote for this rampaging curiousity:D
#18 KennyP ONLINE
  • 38,191 Thanks
  • 45,842 posts
Posted February 09, 2012 - 08:57 AM
Not sure if you can read the label, so I grabbed a screen shot of the first part of the MSDS.
I see nothing that says to sand before top coat, but I try to at least skuff lightly before I do. Here's the pics:
  • Toolpartzman said thank you
#19 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted February 09, 2012 - 09:11 AM
[ATTACH=CONFIG]29638[/ATTACH] [ATTACH=CONFIG]29637[/ATTACH]
Thanks Kenny-Lowes doesn't carry your product and apparently the Acetone needs a "partner" chemical-the resin?- etc to work as a "home brew". Oh well, worth a try. I'll keep shopping.
#20 KennyP ONLINE
  • 38,191 Thanks
  • 45,842 posts
Posted February 09, 2012 - 10:10 AM
Lee, I buy it all the time at Lowes here.
#21 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted February 09, 2012 - 10:23 AM
Lee, Acetone is a solvent that will evaporate very quickly so I doubt that it has any long term effect on the product. Acetone is an awesome degreaser, so if you apply it to bare metal it will probably encourage rusting rather than retard it. In the MSDS Kenny posted there is an ingredient that is proprietary. That is most likely the magic in that product. I haven't had a lot of trouble with flash rusting after the e tank but the humidity is not as high up here as it can be in other areas. That may be a big factor.
#22 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted February 10, 2012 - 04:44 AM
Yeah, I noticed that proprietary note-not likely they'd share. I use Acetone to clean before painting with acrylic lacquer. Its great, but you're right. It evaporates in seconds. Our humidity is a major factor here-Lee
