312-8 year
27 replies to this topic
#16 Ryan313 OFFLINE
  • 3,404 Thanks
  • 5,241 posts
Posted February 08, 2012 - 09:50 PM
I know they offered a deck with two blades and one with three blades, mine has two so I assume its a 36 inch cut. I am 110% sure it only has one belt. I remember because the last time I had the deck off I had a hard time figuring out how it snaked through all the pullies. Its also a double v belt, I know that much.
#17 caseguy OFFLINE
  • 1,629 Thanks
Posted February 08, 2012 - 09:56 PM
Sorry, That's a new one on me LOL. I have probably 5 mower decks lying around for the "C" and the 300/400 series tractors and they're ALL 3 blade, 42" side discharge units. I'll bet that wont be a cheap belt though! It's got to be very long! I did some more digging and I just can't seem to find the info for you. A model number off of the deck might help though.
  • Ryan313 said thank you
#18 Ryan313 OFFLINE
  • 3,404 Thanks
  • 5,241 posts
Posted February 08, 2012 - 10:04 PM
That's the reason I don't have a belt now! Its very long and its gotta be over 100, or very close to it. I need one before spring though, with this one I have to stop a bunch for the blades to catch up. I will look at the deck for model numbers tomorrow, hopefully somebody will come along who knows what I need.
#19 GWest OFFLINE
GWest
  • 553 Thanks
  • 505 posts
Posted February 09, 2012 - 04:08 AM
The 2-blade decks are 37" side discharge. Easy to ID because the left spindle is farther ahead than the right. There are 4 different models
05-37SC01 uses all V-pulleys including the idlers with a 6-sided belt 1986-1990.
Mower Rotary spindle belt Toro 111178 [HA/Ax140.5"]
No replacement @ Gates
No replacement @ Napa
265-001 Stens 1/2"x140-1/2" Double-V
Not listed @ Goodyear
Not listed @ Dayco
.500"x140.5"
There is a product service bulletin showing how this 6-sided belt must be installed. Very important.
A 1990 model 05-37SC02, 1991-1993 model 05-37SC03, and 1993-1998 model 78315 used a 110265 regular belt with flat idlers for the backside of the belt
Mower Rotary drive belt Toro 110265 Replaces 103635 and 107680 [HAx141"]
No replacement @ Gates 6652 (6652BR 1/2"x139-5/8" may work?)
No replacement @ Napa (6652BR 1/2"x139-5/8" may work?)
Not listed @ Stens
Not listed @ Dayco
.500"x141"?
Garry
  • caseguy and Ryan313 have said thanks
#20 Ryan313 OFFLINE
  • 3,404 Thanks
  • 5,241 posts
Posted February 09, 2012 - 06:40 AM
Thanks Garry! Do you have the bullitan or know were I can find one, about the belt inhalation?
#21 GWest OFFLINE
GWest
  • 553 Thanks
  • 505 posts
Posted February 09, 2012 - 01:21 PM
You can download the file from
wheelhorsetractormanuals8 : Wheel Horse Tractors Manuals 8
named
WH61-90 #402 Mower belt install 37in SD 05-37SC01
Membership is required.
There are a few service bulletins posted here with the manuals somewhere. Might check those first to see if it is there but don't know that the file will be named the same.
Garry
#22 Ryan313 OFFLINE
  • 3,404 Thanks
  • 5,241 posts
Posted February 09, 2012 - 01:43 PM
Thanks again, I'll look on those sites and let you know how it works out.
#23 Ryan313 OFFLINE
  • 3,404 Thanks
  • 5,241 posts
Posted February 11, 2012 - 01:58 PM
I couldn't find anything on those sites, lots of info on them and it was kinda overwhelming. I think i looked pretty good though.
this is what I found on the deck.
#24 GWest OFFLINE
GWest
  • 553 Thanks
  • 505 posts
Posted February 15, 2012 - 03:07 AM
See if this works.
Edited by GWest, February 15, 2012 - 03:08 AM.
#25 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted February 15, 2012 - 03:23 AM
Nice Tractor Ryan!
#26 GWest OFFLINE
GWest
  • 553 Thanks
  • 505 posts
Posted February 15, 2012 - 03:26 AM
Your model number needs to be written with a dash to find info 05-37SC01
Your deck's serial number is the 12815.
9024 is the Julian build date - 24th day of 1989 - Tuesday January 24th, 1989
I think there are over 600 service bulletins posted in about 5 different series. They are all in there aphabetically with the WH and T separating Wheel Horse and Toro depending who generated the bulletin. Then the years they cover and next the number they used for the bulletin. There are many more not posted but they are for Toro designed product.
You should be able to paint the top side of the belt or the bottom to make it easier to follow.
Garry
#27 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted February 15, 2012 - 04:07 AM
Hey Ryan me again, I did some checking The best price on the belt is on Ebay, the seller even happens to be someone I buy form all the time. item # is 300429884540. Part # is 111178, it's a Stens belt 140 1/2" long double V and 1/2" wide. the Price is 45.95 free shipping.Just thought I'd pass this along to you. Good luck!
#28 Ryan313 OFFLINE
  • 3,404 Thanks
  • 5,241 posts
Posted February 15, 2012 - 06:54 AM
Thanks guys, both very helpful posts. I will check around and see what other prices are at a few places.
