Checking/adjusting engine RPM?
12 replies to this topic
#1 alsjunk OFFLINE
alsjunk
  • 13 Thanks
  • 14 posts
Posted February 05, 2012 - 02:22 PM
What do you guys use to check a small engines RPM? Thanks for any info.
#2 olcowhand ONLINE
  • 44107 Thanks
  • 32302 posts
Posted February 05, 2012 - 03:38 PM
I used to use a "Vibra-Tach"
But now I use a photo digital tachometer. VERY accurate! Just put a small piece of reflective tape on the crank, or anything that rotates with the crank, then point the tach at it, push button....and exact rpm's come up.
  • dstaggs and IamSherwood have said thanks
#3 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 181 Thanks
  • 1009 posts
Posted February 05, 2012 - 11:28 PM
Agree, photo tach is the most universal way of doing it
#4 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 06, 2012 - 08:19 AM
I'm guessing you did some researching before you bought that digital tach Olcowhand.
Have you got anymore details about it? Make, model?
I have one of those vibratachs, but find it a bit too much of a ordeal to get an accurate reading.
Thanks
#5 KennyP OFFLINE
  • 53159 Thanks
  • 53301 posts
Posted February 06, 2012 - 08:36 AM
Will, it looks real close to this one:
Photo Tachometer DT2234A (Laser)--shore durometer|coating thickness gauge|Graigar Instruments Co.,Ltd.
#6 olcowhand ONLINE
  • 44107 Thanks
  • 32302 posts
Posted February 06, 2012 - 09:59 AM
Thanks
It's up at Meangreen's right now, but I'll get the make later. I paid around $2 for it, shipping & all! One of those online shopping places (can't remember which) sent me a coupon code for $15 off any purchase, and this the tach had free shipping. So ended up around $2. No-brainer to buy it!
  • IamSherwood said thank you
#7 TerryD OFFLINE
TerryD
  • 133 Thanks
  • 254 posts
Posted February 06, 2012 - 10:23 AM
I have one of the digital tachs as well. Just apply a piece of reflective tape (included with mine, and I'm sure most) attached to the driveshaft, point and click. I like that I can move it from machine to machine without unwiring and rewiring.
http://www.amazon.co...s00_i00_details
#8 brokenbudget OFFLINE
brokenbudget
  • 19 Thanks
  • 178 posts
Posted February 06, 2012 - 06:39 PM
a silver sharpy marker works just as good if the shiny sticker doesn't want to stick:give_me_beer:
  • coldone, Alc and IamSherwood have said thanks
#9 Billygoat OFFLINE
Billygoat
  • 76 Thanks
  • 206 posts
Posted February 06, 2012 - 08:40 PM
brokenbudget is right about the silver Sharpie- it works like a champ against a dark background. I have one like TerryD shows. Got it off of Ebay, paid about $15.
#10 KennyP OFFLINE
  • 53159 Thanks
  • 53301 posts
Posted February 07, 2012 - 07:57 AM
For the reflective tape, if you happen to have any of the foil tape for heating/air ducts, that would work. I also have the silver pencil for marking metal for cuts, got it when I was picking up welding supplies.
Edited by KennyP, February 07, 2012 - 08:03 AM.
#11 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1189 Thanks
  • 1342 posts
Posted February 07, 2012 - 09:01 AM
The prices have really dropped since I bought my digital tach back in 2001 for $150 which was cheap back then. But then again it is over 10 years old and still works great. It also has the adapters for measuring belt speed.
Bill
#12 alsjunk OFFLINE
alsjunk
  • 13 Thanks
  • 14 posts
Posted February 10, 2012 - 08:11 AM
Thanks to all! I have one on the way.
#13 cookiemonster OFFLINE
cookiemonster
  • 410 Thanks
  • 1274 posts
Posted February 10, 2012 - 12:55 PM
I second, third, fourth that motion on the photo/reflective.
just make sure that you affix the reflective tape on a dull surface. Or use something like electrical tape all the way around and then put the reflective block on top. If you're measuring off a shiny surface it'll jump around wildly on you. If you see that, stop and make sure that your tape is the only shiny spot it's "seeing"
