snow plow hieight off ground
16 replies to this topic
#1 jlpowell OFFLINE
jlpowell
  • 3 Thanks
  • 37 posts
Posted February 05, 2012 - 01:27 PM
pk 1614 quick question how far off the ground should snow plow raise off the ground? i think it is using wrong bars . don't have it home yet but i know it only raises about 1to 2 inches
#2 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,115 Thanks
  • 4,887 posts
Posted February 05, 2012 - 02:31 PM
Welcome to GTTalk! If you have the factory lift bar it will have several holes for adjustment. If the liftbar has been replaced you can just drill some new holes to get the desired stroke/lift.
#3 Ryan313 OFFLINE
  • 3,364 Thanks
  • 5,230 posts
Posted February 05, 2012 - 04:22 PM
First, Welcome To GTtalk! Kris is right, they are adjustable. What year is yours? If its 62 or later (I think that's the year) it should have a rod with a spring, a blocky looking thing, some R-pins and possibly some washers. If you post some pics we should be able to tell you.
#4 jlpowell OFFLINE
jlpowell
  • 3 Thanks
  • 37 posts
Posted February 05, 2012 - 06:09 PM
wont know exact year until it makes it home the bar that is on it has a fork on each end goes mid way of tractor to plow any one have a pic of correct bar and i believe the year to be 81 to 84
#5 Ryan313 OFFLINE
  • 3,364 Thanks
  • 5,230 posts
Posted February 05, 2012 - 06:30 PM
For those years they had the hydraulic cylinder under the tractor, I dont know how those are hooked up but, once you get it, Im sure we can figure it out if you post some pics of the underneath
#6 jlpowell OFFLINE
jlpowell
  • 3 Thanks
  • 37 posts
Posted February 05, 2012 - 07:12 PM
well i'll have to wait til it gets here and post back at that time. still probally 3 weeks before it arrives.
#7 Ryan313 OFFLINE
  • 3,364 Thanks
  • 5,230 posts
Posted February 05, 2012 - 07:23 PM
Are you getting it shipped to you? I should be able to find you something before it gets to you.
#8 jlpowell OFFLINE
jlpowell
  • 3 Thanks
  • 37 posts
Posted February 05, 2012 - 07:52 PM
helped a freind restore 8n ford to get power king but he wanted to hang on to it to scrap store parking lot this year before he let me take it
#9 Ryan313 OFFLINE
  • 3,364 Thanks
  • 5,230 posts
Posted February 05, 2012 - 08:17 PM
Seems like a fair deal to me, have fun working on a tractor, and get a great machine in return! win win situation!
#10 jlpowell OFFLINE
jlpowell
  • 3 Thanks
  • 37 posts
Posted February 05, 2012 - 08:45 PM
can't complain about it at all was a blast doing 8n but we be more fun doing MY POWER KING
#11 jlpowell OFFLINE
jlpowell
  • 3 Thanks
  • 37 posts
Posted February 05, 2012 - 09:03 PM
any idea what would be needed to add second transmition
#12 Ryan313 OFFLINE
  • 3,364 Thanks
  • 5,230 posts
Posted February 05, 2012 - 09:25 PM
First of all, another transmission... and 2 drive tubes that are like the one with a single transmission just longer. To buy everything be prepared to spend about 400-500 bucks, at least. Unless you are going to use it for snow blowing or tilling you don't need it, but I understand wanting it. I have the double setup in my 75 and 95% of the time the rear tranny stays in 3rd. 3rd gear has a 1:1 ratio so its like having a single transmission if one is in 3rd. The only time I gear it down more then that is when im going down a steep hill with a load on. Do you plan to restore your power king? If you do make sure to start a thread with lots of pics following your progress!
#13 MH81 OFFLINE
Posted February 05, 2012 - 10:40 PM
I see you're already getting some great help.
Congrats on your PK & :ditto: on the pics when you get it home.
:welcometogttalk:
#14 jlpowell OFFLINE
jlpowell
  • 3 Thanks
  • 37 posts
Posted February 06, 2012 - 06:21 AM
i do plan on making look better than it does now .but it will be put work . would like to set for tilling that is the reaso for 2nd trans questions . already have deck here it is missing one idler pulley and one locked up
#15 KennyP ONLINE
  • 37,478 Thanks
  • 45,498 posts
Posted February 06, 2012 - 06:38 AM
Welcome! Glad you have the tractor, can understand wanting to get it home. Sounds like you will have good help figuring things out. Good luck with it.
