Found this on Ebay
10 replies to this topic
#1 timtractor OFFLINE
timtractor
  • 224 Thanks
  • 376 posts
Posted February 04, 2012 - 10:31 AM
:wave: Maybe this attachment might help out sombody, or give them another project to produce.
This one is mounted on a Gravely but it looks like it should fit on an sleve hitch.
#2 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted February 04, 2012 - 11:03 AM
Nice little jin pole boom.
#3 KennyP ONLINE
  • 40,124 Thanks
  • 46,764 posts
Posted February 04, 2012 - 11:35 AM
That's cool. Lots of ideas there, Casey.
#4 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Thats easy enough! Looks handy.
#5 OldBuzzard ONLINE
OldBuzzard
  • 7,082 Thanks
  • 4,809 posts
Posted February 04, 2012 - 11:42 AM
... but it looks like it should fit on an sleeve hitch. ...
If you look close, you will see that it IS on a sleeve hitch :D
Definitely would be a handy rascal.
How much are they wanting for it?
#6 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted February 04, 2012 - 11:56 AM
I know what you mean Kenny, would be handier than sleeve hitch forks (original plan of mine). Talk about moving implements, even if you use a longish chain with a grab hook on it to be able to loop around the item and hook back on itself, then pick up the hitch, holy crap, Kenny.. you could draw me your version of that if you're bored LOL.
#7 KennyP ONLINE
  • 40,124 Thanks
  • 46,764 posts
Posted February 04, 2012 - 12:47 PM
Sorry, Casey. Working on dentures for the box blade.
#8 tinner OFFLINE
tinner
  • 503 Thanks
  • 1,561 posts
Posted February 04, 2012 - 03:24 PM
Kenny:
Are you putting hardened teeth on the box blade? I have everything I need to build one, just need to get off my lazy butt and get to work.
#9 KennyP ONLINE
  • 40,124 Thanks
  • 46,764 posts
Posted February 04, 2012 - 04:03 PM
Well, Ronnie, the metal I am using was the top strap from an Oxy/acet. cart. I tried to straighten the bends in it by hand and couldn't do it. So I guess it is hardened. I even put it down on the 50 lb. block I have and stood on it. Still didn't bend it back any. Took a bit to drill holes for the slots. I had to get out the 4 lb. sledge and straighten it so I could cut the pieces out of it. Definitely better than what you get from Lowes.
Check out the thread: http://gardentractor...ox-blade-12161/
#10 MH81 OFFLINE
Posted February 04, 2012 - 06:39 PM
Tim, nice looking boom. Bet the winch would come in handy. I made one for my Sears, but it was just a boom, no winch.
#11 timtractor OFFLINE
timtractor
  • 224 Thanks
  • 376 posts
Posted February 06, 2012 - 01:50 PM
:wave: I went back to try to find it but I couldn't find it. :confuse:
I remember seeing that the guy was asking $200.00 for it.
It looks like the poll can be extended for longer reach.
You would think that you would have to have some weight on the front end of the tractor or the front end of the tractor would not be able to turn.
