* * * * * 1 votes
Goodwood Cultivator
114 replies to this topic
#31 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted February 07, 2012 - 12:56 PM
Here's a Coldwood at work,...Colwood Motor Hoe at work - YouTube
  • tractorgarden and john webster have said thanks
#32 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted February 07, 2012 - 09:59 PM
I guess it was not the engine smoking under load, It was the operator! neat machine!
  • john webster said thank you
#33 john webster OFFLINE
john webster
  • 89 Thanks
  • 118 posts
Posted February 09, 2012 - 02:05 PM
This little wonder can move more quickly than i can run ! Hope mines not as fast or it will leave me behind.
#34 john webster OFFLINE
john webster
  • 89 Thanks
  • 118 posts
Posted February 12, 2012 - 09:44 AM
hello again. i have started to strip down the goodwood so that i can refub engine and rub down for paint the engine is a villiers MK 25 A and the gearbox is a four speed ALBION with NO reverse.all drives are chain driven and will now show some photos of strip down.11022012737.jpg 11022012736.jpg 11022012736.jpg 11022012740.jpg 11022012743.jpg 11022012744.jpg 11022012745.jpg 11022012746.jpg
Edited by john webster, February 12, 2012 - 09:46 AM.
  • tractorgarden said thank you
#35 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted February 12, 2012 - 11:03 AM
Looking really good John, what a neat little Culti-unit,
#36 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted February 12, 2012 - 05:01 PM
Thank you John for keeping us posted!
#37 john webster OFFLINE
john webster
  • 89 Thanks
  • 118 posts
Posted February 14, 2012 - 03:26 PM
started on the engine and the only damage that i can find which needs attention is the compression.have checked the piston,rings and bore but they looked all in order. i then decided to remove tappets and when i got them out i found the exhaust valve seat burnt very badly. but this was soon put right with a hand opperated valve seat grinder.when satisfied i lapped both valves with grinding paste and refitted.must have been a sucsess as now have dificulty turning by hand on compression stroke.
#38 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted February 14, 2012 - 04:08 PM
John, if you don't mind, im compeled to ask, did this engine take a metal type of head gasket or the fiber type, and is the compression the normal 6 to 1 ?
#39 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted February 15, 2012 - 01:54 AM
What an awesome piece of machinery !!!!
#40 john webster OFFLINE
john webster
  • 89 Thanks
  • 118 posts
Posted February 17, 2012 - 02:30 PM
hi trowel. yes these engines have a doble sided copper gaskit as standard,and not sure of compression but i know this one is very,very good.
  • trowel said thank you
#41 john webster OFFLINE
john webster
  • 89 Thanks
  • 118 posts
Posted February 17, 2012 - 03:01 PM
this project is marching on now but only spending an hour a day when i can.new ignition coil due soon so to keep momentum going have started to paint certain items.this paint is a brush on polymer based paint which has a high gloss finish and is easy to apply.16022012762.jpg
#42 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted February 17, 2012 - 05:58 PM
Very sharp green paint, i can already see that this is going to come out so nice, did you use a full engine block gasket kit or made your own ?
#43 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted February 18, 2012 - 04:15 AM
Its kind of fun watching this thread in two completely differnt types of groups, and seeing the answers both the same and completely differnt.
#44 john webster OFFLINE
john webster
  • 89 Thanks
  • 118 posts
Posted February 18, 2012 - 10:17 AM
well it is funny that you ask because with the copper gaskit which was a standard fittment for the MK 25 you could aneal it on a cooker ring and bring the softness back in the copper,so if it was not damaged you could use time and time again
  • tractorgarden and chris m have said thanks
#45 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted February 18, 2012 - 01:27 PM
Looks sharp John!
