If I want to run E 85 in my tractor what changes do I need to make ? Just alcohol carb and fuel pump ? Or is there more because it burns hotter like different spark plug or gap ?
E85
Started by
Dennis Cain
, Feb 02, 2012 08:48 AM
3 replies to this topic
#1 OFFLINE
Posted February 02, 2012 - 08:48 AM
#2 OFFLINE
Posted February 02, 2012 - 10:39 AM
See if I can help with this a little. Been playing with 2-strokes and ethanol a little lately. The two big things you have to worry about is compatibility (hoses, gaskets, float needle, and diaphragms), and BIGGER jets. I have had the rubber on the tips of float needles disintegrate, gaskets swell, and hose turn to jelly.
Ethanol has less BTU per volume than Gas so you have to run larger jetting. And it does run cooler, you may want to bump your plug one heat range.
One of the biggest benefits is you can run more advanced timing and higher compression and not worry about detonation. Ethanol has a higher octane rating. Not sure if that will be a benefit with the lower rpms and minimal advance on gt motors.
One of the big drawbacks is its affinity for water. Moisture and condensation go right into solution and reeks havoc on things.
#3 OFFLINE
Posted February 05, 2012 - 03:58 AM
I run alky on one of my pullers and had to rejet the carbs with stainless steel jets,change over to braided steel lines and e3 plugs.still have to change the oil after a weekend of pulling cause the alky being thin,some always ends up in the oil,
#4 OFFLINE
Posted April 23, 2012 - 12:44 AM
why not add a bottle of hear or gas drier if they make in i am not really sure
