Power King with Brantly Backhoe
This topic has been archived. This means that you cannot reply to this topic.
7 replies to this topic
#1 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted February 01, 2012 - 11:40 PM
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
#2 mjodrey OFFLINE
Posted February 02, 2012 - 05:44 AM
That would be nice to have.
#3 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted February 02, 2012 - 09:11 AM
I saw that a few days ago, stared at it for a good 10 minutes at least. That tractor weighs around 900lbs bare, with the attachments it says its 3000lbs. I think that's to much weight for those axles and spindles. That's said, I'd love to have it still.
#4 1967bolens collector OFFLINE
    Deceased
  • 654 Thanks
  • 1,441 posts
Posted February 08, 2012 - 12:00 AM
for 4,400 i would have to have something bigger then that. and that bucket is way to big for that tractor.
#5 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted February 08, 2012 - 10:57 AM
The bucket is probably good sized for it. Has alot of weight with that backhoe. But the backhoe looks like a toy, it has no power steering, and is gear drive
#6 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted February 08, 2012 - 07:08 PM
The fel is a factory setup actually, the bucket does look larger then most but it seems to be factory made. The backhoe is pretty small, but it probably takes some weight of of the front wheels to steer easier. Also, what would drive would you want on that tractor? Is gear drive a bad thing on something like this?
#7 Lovintractorin OFFLINE
Lovintractorin
    Tinkerer
  • 159 Thanks
  • 603 posts
Posted February 08, 2012 - 09:32 PM
I personally like gears drive for almost everything. But FEL work is where a hydrostatics really shines. Makes it a really easy to move forward and back and change speeds as you are going into a pile, scraping or loading a truck. On a gear drive that is a lot of clutch work.
#8 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted February 09, 2012 - 01:04 AM
Basically. too much operator input to work enjoyably
