Brinly plow setup
6 replies to this topic
#1 OldBuzzard OFFLINE
OldBuzzard
  • 7,097 Thanks
  • 4,816 posts
Posted January 30, 2012 - 09:15 AM
I stumbled on this web page on how to setup a Brinly plow:
Preparing Plow for Use:
Could some of you that use plows check it out and critique it?
I may be plowing and tilling @1/4 acre this spring/summer and while I have no experience plowing, I know that a proper setup makes a world of difference.
I'll most likely be using a Bolens 1886 for this.
ETA:
The ground I'll be working has never been plowed.
Edited by OldBuzzard, January 30, 2012 - 10:21 AM.
  • farmer john said thank you
#2 Bolens 1000 OFFLINE
  • 15,432 Thanks
  • 18,284 posts
Posted January 30, 2012 - 09:22 AM
That seems like a pretty good link you posted
Oldcowhand also posted an article on how to adjust a 1 bottom plow here : Garden Tractor Talk - Proper way of setting up a one bottom plow
#3 MH81 OFFLINE
  • 29,979 Thanks
Posted January 30, 2012 - 12:45 PM
That's an excerpt of the original Brinly plow manual.
A copy of which can be found at GTT here:
Brinly Moldboard plow Operators manual - Manuals - Garden Tractor Talk - Forums
  • Bolens 1000, caseguy and HowardsMF155 have said thanks
#4 jessy OFFLINE
jessy
  • 3 posts
Posted April 10, 2012 - 12:04 AM
ok guys the info at the top helped alot i had made my sleve hich for my jacobson chife some of u may have seen it well i was wondering is dose the brinley plow have to flout a little bc i had made my braket were it dose not flot my setup is hidrolic up and down
i was just looking for some insite on how to set it up right
#5 mjodrey OFFLINE
Posted April 10, 2012 - 04:22 AM
Thanks for posting the link,OB.
#6 HowardsMF155 OFFLINE
  • 2,969 Thanks
  • 3,018 posts
Posted April 10, 2012 - 09:09 AM
I don't think the plow has to float up and down much. I think it should have room to float side to side a few degrees to find it's own running angle. Also, you need to make sure that the right hand plow edge will come right to the side of your last furrow; in other words, don't try to take too big a bite with the plow by having it too far to the left.
#7 MH81 OFFLINE
  • 29,979 Thanks
Posted April 10, 2012 - 11:26 AM
The brinly plows were designed to operate with out down pressure. You may want to try a manual bypass valve or something that allows you to have a "Float" position. On the other hand, it would all but eliminate the need for the fine tuning we all go thru. Trying to get it to work "Just Right" has caused many to add 20# to the plow for a little more gravity down pressure.
