DIY Reverse Light ('74 John Deere 110)
17 replies to this topic
#16 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,089 Thanks
  • 1,284 posts
Posted January 29, 2012 - 09:57 PM
wvbuzzmaster,
Thanks. I am enjoying the site. I would love to see your set up once you've completed your install. Regarding the momentary switch, I'd be interested in learning more about which momentary switch you might be referring to; push button, toggle, etc. Thanks again and I look forward to seeing a pic of your install if you;re able to.
Matthew
#17 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted January 29, 2012 - 10:07 PM
Matthew, I was thinking toggle would do it just fine on it's side, but I have to determine exact mounting method, and finally have to bolt the shift plate down LOL. It has been flopping around for couple years now lol. I think I could make it work out just fine being an electrician lol.
Heck, just a pair of spring clips and the shifter complete the circuit.
#18 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted January 30, 2012 - 10:00 AM
Matthew,
Go ahead and post the questions on here. I saw your question about the extra wire, and it is for the cigarette lighter. As for the valve stems on front wheels, I always mount mine to the inside, so that they don't interfer with mounting the hubcaps. I think most tractors have the front wheels mounted with the valve stems towards the inside, come to think of it. Each tractor type is different though, when it comes to the rear wheels and valve stems, as I have seen inside and outside mount.
Troy
