Raise your hand if you want to answer my stupid question!
38 replies to this topic
#31 Ryan313 OFFLINE
  • 3,360 Thanks
  • 5,228 posts
Posted February 24, 2012 - 04:10 PM
Well after some :wallbanging: and a little blood I got the lift for the drawbar off. Here is the bent arm, I had already cut it off when I took the pic so its not in the right spot. The bar in the middle connects the lift to the drawbar, it got a little bent as well.
When I was cutting the bent arm off I hadn't realized how far I was cutting into the bar. Im going to have to weld in the cut and grind it flat, no big deal.
Edited by bmxkid313, February 24, 2012 - 04:11 PM.
#32 ariensman2 OFFLINE
ariensman2
  • 8 Thanks
  • 22 posts
Posted February 25, 2012 - 03:23 PM
It's nice that these tractors are made of solid steel and are easy to repair or modify. I'm sure you'll have it just like new soon. Keep up the good work.
  • Ryan313 said thank you
#33 Ryan313 OFFLINE
  • 3,360 Thanks
  • 5,228 posts
Posted February 25, 2012 - 04:11 PM
Thanks Dave! I dont think it will be hard to fix, I got the lift arm pretty well straitened out. I think im going to have to add a gusset or something for strength. When i cut it off I had to remove a good size piece.
#34 Ryan313 OFFLINE
  • 3,360 Thanks
  • 5,228 posts
Posted February 25, 2012 - 05:40 PM
I welded in that cut that made while taking the arm off, and gridded it down. The other piece is the arm after I straitened it out, It was a complete circle on one end but i had to remove a chunk to take it off.
I welded the arm back on and put some round bar on each arm to give it some strength. The one side didn't really need it but I thought it would look better if it matched.
Now I just have to sand it and paint it, then I can put it back to use!
#35 ariensman2 OFFLINE
ariensman2
  • 8 Thanks
  • 22 posts
Posted February 25, 2012 - 07:00 PM
Looks good Ryan!! Should be nice and strong. Just a little safety tip: If your welding and grinding inside your garage remember to check back after you leave a few times because sometimes thats how fires start and keep all combustible items away. Those weld beads look good, do you have a MIG?
#36 Ryan313 OFFLINE
  • 3,360 Thanks
  • 5,228 posts
Posted February 25, 2012 - 07:19 PM
Thanks, I have a small mig welder that I use quite a bit. Those welds aren't my best but I think they are strong enough for what I need them for. Im not a very good welder anyway. I will check the garage after Im done from now on, thanks for pointing it out to me.
#37 ariensman2 OFFLINE
ariensman2
  • 8 Thanks
  • 22 posts
Posted February 25, 2012 - 07:40 PM
Well thats good, a mig can give you a much cleaner bead and the trick is to get the 2 pieces of metal to get penetrated with your melting wire. All I have at home is a little AC buzz box that works ok with 6011 rod but the bead isn't too pretty. I remember years ago when I was at the sawmill I used to use a MIG for my projects and I could run a beautiful bead with it but had to make sure it penetrated the metal and not just sit on top of it.
#38 Ryan313 OFFLINE
  • 3,360 Thanks
  • 5,228 posts
Posted February 26, 2012 - 10:14 AM
My best weld on this project is the one holding the arm to the bar. The welds for the corner supports aren't as nice.
#39 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted February 26, 2012 - 12:09 PM
Looks good to me Ryan. Good work on fixing your breaks.
