Power angle for a snow plow
3 replies to this topic
#1 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted January 28, 2012 - 12:24 PM
I am looking for a way to build an electric device to angle my snow plow. I have an idea with a piece 0f 3/4" threaded rod and an electric motor, I just have not drawn up anything yet. Does anyone have any other ideas? I do not want to buy an actuator or any other parts with a significant price tag. I have a lot of misc. parts in the garage to use.
Geno
  • 14,730 Thanks
  • 15,470 posts
Posted January 28, 2012 - 02:45 PM
What is the voltage the actuators used on those big old satellite dishes, I was thinking they were 12VDC. You can look around for 1 of those, depending on where you are at, I still see them in people's yards and would give you the dish to remove it. Just a thought..
#3 Michiganmobileman OFFLINE
Posted February 01, 2012 - 07:36 PM
How about a power window motor? I used a GM one as a spout rotator on my snowblower, you can use a 12 point socket right over the gear that is on the window motor, I think 7/8 or 13/16. That in a 1/2 inch drive and some grinding on your all thread down to the right drive size and you are partway there.
You would have to play some I would think to get the right leverage to move the blade and may not be able to move it while full but should be workable.
  • bgkid2966 said thank you
#4 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted February 05, 2012 - 01:45 PM
I like the idea of a window motor for power. I have one and just tested it. I also have the 3/4" threaded rod and tubing to build the actuator. I look forward to getting the time to work on it.
